I am capturing the images from the Jetson Nano Camera. The images are coming with little purple tinge… I tried with different resolutions like 640x480 and 1280x720. In all resolutions the picture quality is same.
I am using camera-capture tool and also tried with imagenet-camera.py code to get the images.
How to get a good quality image?
Where can I do the camera related settings like adjusting the brightness, color, contrast, white balance etc?
I believe it’s a hardware issue with the camera module but it can be corrected with a profile, so it’s not so bad. Not exactly a Hasselblad, but better than pink all over.
Thank you.
The suggestions in that link helped to improve the picture quality. Pinkish is much reduced.
There is grainy issue still… I think I need to use v4l2 utils and send capture parameters to tune the picture quality.
The gstreamer Argus source allows control of many of the same options, I believe. If you Google, you will find the “accelerated gstreamer users guide” with details.
