I’ve recently receive some jetson nano labelled as “Jetson Nano developer kit V3”, which turns out to be the B01 varient of the Jetson Nano dev kit but has the boot firmware moved to the QSPI flash as mentioned in R32.5.1 release note (https://developer.nvidia.com/embedded/linux-tegra-r325).
The main issue I have is that the os that we’re using is still in 32.4.4 (we’re using BalenaOS balenaOS - Run Docker containers on embedded IoT devices) which was build on Yocto. Since the u-boot is now moved towards the qspi flash for this specific “V3” dev kit from the vendor, I attempted to flash revert the qspi firmware back to R32.4.4.
I’ve tried to flash the qspi using R32.4.4 using the ./flash.sh script included in the BSP archive (BSP archive available here: https://developer.nvidia.com/embedded/L4T/r32_Release_v4.4/r32_Release_v4.4-GMC3/T210/Tegra210_Linux_R32.4.4_aarch64.tbz2). The steps I did was:
- remove sd card
- place jumper between GND and FC REC
- remove jumper on J48
- plug in Micro USB cable to Nano and host
- lsusb return Nvidia USB receiver
- run
sudo ./flash.sh -k LNX jetson-nano-qspi-sd mmcblk0p1 - flash was successful
- remove micro USB
- remove jumper between GND and FC REC
- put jetpack image sd card in
- attach to console debug output
- plug in micro usb to power on device again
- no logs from console debug
- checked host
lsusband Nvidia USB receive device still exist
I’ve tried this on 2 separate ‘V3’ nano and are getting the same result. I’ve looked around the forum and it seems like some other people are facing this issue as well, however most of it was pointing to a hardware error.
I felt like I’m doing something wrong and is causing the device to stuck in the recovery mode.
Any help would be appreciated, thanks in advance!
flash.sh output
uboot-flash-output.txt (13.4 KB)
