My Jetson nano developer kit b01 is not booting up. I can see it’s powered up, I can see the led light is turned on. I have flashed the sd card with jetpack os and inserted in nano. But the nano is not booting up.
I have replaced sd card and re downloaded the os, still I’m facing same problem. I’m using correct power supply for this. Even after doing everything correctly the board is not working.
