After several attempts, putting the flash image of the distribution “Jetson-nano-jp441-sd-card-image” downloaded from your portal after the image of Nvidia at boot does nothing, I also tried to change microsd but the same does nothing after the appearance of the logo.
It may be that my Jetson Nano arrived already broken, I await your clarification
Jetson Nano Developer Kit
Only the nvidia logo keeps coming back to me:
- Flashed the corrected image several times from https:///developer.nvidia.com/jetson-nano-sd-card-image-441
- Powered with 5V and 3A with a good microusb power supply (also tested with various other power supplies and cables)
- Also tested with another microsd
- attempted to bridge over J48
I have no idea what it might be, I await your polishing
Please find the below link for the proper guidance for SD card boot for Nano.
@SeetharamNS I followed the same guide and followed step by step directions but still do not boot
OK.
Try with SDK manager once. Reference attached below.
Just to clarify. What did you do after follow the recommendation? What steps did you do?
I feel you didn’t do anything there…
