I’d like to power my Jetson Nano by the GPIO pins with a Pixhawk flight controller, but the Jetson Nano doesn’t stay on when I do so.
At first, the Jetson Nano would turn on for around 5 seconds before shutting off completely. After I shortened the power cables twice, it stays on for a bit longer before shutting off, then it turns back on after being off for a second and so on – this loop seems to continue until I unplug the battery from the Pixhawk.
I don’t think this is an issue with the Pixhawk, so I’m wondering if something needs to be configured in the Jetson Nano to prevent this? Or maybe the connection between the cables I’ve spliced together are causing a problem? Any thoughts would be greatly appreciated.
