Hi i have an odd situation
I have jetson nano b01 with 16gb emmc and i use custom carrier board
My jetson was working fine till it doesn’t anymore and failed to boot
I’ve tried to flash it with sdkmanager the flash is successful and when i choose runtime it’ll boot and i go through accepting user agreement and creating username and password and all but then it will start detecting hardware and configuring hardware and making Changes and then the jetson reboots and stucks in the bootloop with the command nvgpu 57000000 :gr_gk20a_fecs_ctx_image_save:1457 [ERR] save context image failed
even i tried flashing with sudo ./ Flash.sh jetson-nano-emmc mmcblk0p1 and the flash was again a success but jetson was blank after using flash.sh i again flashed with sdkmanager and this time Jetson booted to os and even booted just fine all the way to os but when i turned off the jetson and turned it on again i was stuck in bootloop with the same error as before
I m frustrated please help
There may be an issue with the custom carrier board, as the flashing method we provide is designed for development kits. Therefore, it is recommended to contact the vendor to obtain the Jetpack BSP.
Hi thanks for the reply and your time
I really appreciate it
I did download the jetpack bsp from the developer site my carrier board is jetson - io - base-a from waveshare but issues didn’t reaolve and im getting the same results and errors as befor
Could you dump the whole log for us to review?
Please refer to below link to dump the UART log.
