Jetson Nano failed to enter Recovery Mode
I have a Jetson Orin Nano and have not flashed it successfully. The device is not working correctly so I am trying to enter Recovery Mode. I have powered the device off, connected pin 9 to pin 10 on the 40-pin expansion header, and then powered it on with the DC Jack. After ~20 seconds, I see the Nvidia splash screen for ~8 seconds with the following options
ESC to enter Setup
F11 to enter Boot Manager Menu
Enter to continue to boot
** WARNING: Test key is used. **
L4TLauncher: Attempting Recovery Boot
After it continues to boot, the screen goes black (same behavior when I don’t have pin 9 and pin 10 connected). I connect the USBC to USBA port on my Linux machine, but nothing new is listed with lsusb .
I have tried several USBC connection cables and also tried a different microSD card. Any other suggestions to enter Recovery Mode?
HI,
Do you follow to QuickStart provided option.
Also use lsusb in your host to check weather the device in recovery mode.
Please refer this section to check.
