we are very interested in using the Gst-nvdewarper plugin, but in the plugins documentation you refer to a config file that does not exists in the configs/ folder :
“These dewarped surfaces are scaled to the output resolution (output-width × outputheight) set in the configuration file located at configs/deepstreamapp/config_dewarper.txt.”
Also, is there any calibration to do for dewarping ?
Really keen to learn more about the dewarping plugin, any additional resource would be welcome !
Please download the latest Deepstream plug-in manual from here:
Section 2.8 of the manual describes the configuration file parameters for the dewarper plugin in more detail, including the projection type and focal length.
I’ve read a few times all the doc nvidia provided, i was looking for more didactical explanations of those parameters.
I guess I’ll have to try and and see :)
