Hi, I have a Jetson Nano input connected from an optocoupler, and it frequently stucks, with some voltage, when there is no external signal.
I have made the next video:
Any help would be appreciated, thanks for reading.
Which pin is in use here?
Hello, I´m using pin 31 and pin 35 in that video (both with the same issue).
Any other question please let me know.
Thank you.
Hi, please refer to the 40-pin header docs first. There are some requests to the usage of these pins.
Hi, thank you for the link.
I have read it carefully but I´m afraid I’m missing something. I understand that maybe I need a pull-up or pull-down resistor but I don´t know if I’m properly connecting the optocoupler to the Jetson Nano pin, or if it is not possible. Just to clarify:
My circuit:
I have also tried with a pull-down resistor (2K), but issue stills the same.
Should I connect all GND PINs (6, 9, 14, 20, 25, 30, 34 and 39) to ground like the example in documentation?
Should I connect PINs 1 and 17 to 3.3v like the example in documentation?
Is it possible in any way a working circuit with Jetson Nano and that optocupler?
Thanks and kind regards.
No experience on this kind of 3rd-party device connection. You can check with vendor for how to connect it to other device.
