Jetson Nano - iwlwifi Driver Causing Firmware Crashes and Disconnections (Intel AC 8265)
Hi all,
We’re experiencing a recurring issue with the Intel Dual Band Wireless-AC 8265 Wi-Fi module on the Jetson Nano Developer Kit (JetPack 4.x). The chip frequently restarts during operation, leading to Wi-Fi disconnections and runtime kernel errors.
System Details:
  • Platform: Jetson Nano Developer Kit
  • Wi-Fi Chipset: Intel Dual Band Wireless-AC 8265
  • Driver: iwlwifi
  • Kernel: [4.9.201-tegra]
  • JetPack Version: [JetPack 4.5.1]
1. Runtime Logs
We see the following kernel logs during runtime when disconnection occurs (note: this is not every time when disconnection happens):
[ 203.918251] ------------[ cut here ]------------
[ 203.957885] WARNING: CPU: 1 PID: 3781 at /home/linux/top_dir/kernel_sources/Linux_for_Tegra/source/public/kernel/kernel-4.9/drivers/net/wireless/intel/iwlwifi/mvm/rs.c:1212 iwl_mvm_rs_tx_status+0x2ec/0x8c0 [iwlmvm]
[ 204.185953] Modules linked in: ipt_MASQUERADE nf_nat_masquerade_ipv4 xt_conntrack ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter nf_nat_h323 nf_conntrack_h323 nf_nat_pptp nf_nat_proto_gre nf_conntrack_pptp nf_conntrack_proto_gre nf_nat_tftp nf_conntrack_tftp nf_nat_sip nf_conntrack_sip nf_nat_irc nf_conntrack_irc nf_nat_ftp nf_conntrack_ftp iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack fuse overlay bnep zram userspace_alert nvgpu iwlmvm mac80211 ftdi_sio btusb btrtl btbcm btintel iwlwifi cfg80211 spidev ar0330(O) bluedroid_pm ip_tables x_tables
[ 204.186037] CPU: 1 PID: 3781 Comm: irq/408-iwlwifi Tainted: G O 4.9.201 #1
[ 204.186039] Hardware name: NVIDIA Jetson Nano Developer Kit (DT)
[ 204.186042] task: ffffffc0eed00000 task.stack: ffffffc0e8674000
[ 204.186098] PC is at iwl_mvm_rs_tx_status+0x2ec/0x8c0 [iwlmvm]
[ 204.186150] LR is at iwl_mvm_rs_tx_status+0x7c/0x8c0 [iwlmvm]
[ 204.186154] pc : [] lr : [] pstate: 60400045
[ 204.186155] sp : ffffffc0e8677a10
[ 204.186158] x29: ffffffc0e8677a10 x28: ffffffc0bab80818
[ 204.186163] x27: ffffffc0bab80ad8 x26: 0000000000000000
[ 204.186168] x25: 000000000d9afffb x24: 00000000ffffffea
[ 204.186173] x23: 0000000000000000 x22: 0000000000000000
[ 204.186178] x21: 0000000000000000 x20: ffffffc0de0e15e8
[ 204.186182] x19: ffffffc0e8677ba0 x18: 0000000000000000
[ 204.186187] x17: 0000000000000004 x16: 0000000000000000
[ 204.186192] x15: 0000000000007dac x14: ffffffc0fa3baa00
[ 204.186196] x13: 0000000000000350 x12: 071c71c71c71c71c
[ 204.186201] x11: 0000000000000605 x10: 0000000000000a10
[ 204.186205] x9 : 0000000000007d80 x8 : ffffffc0eed00a70
[ 204.186210] x7 : 00000000000008fa x6 : 0000000000000000
[ 204.186214] x5 : ffffff80013837e0 x4 : 0000000000000000
[ 204.186219] x3 : ffffffc0e8677ba0 x2 : 00000000000000ff
[ 204.186224] x1 : 0000000000000001 x0 : ffffff800139925b
[ 204.186230] —[ end trace d5ac9942a3b68e71 ]—
[ 204.241127] Call trace:
[ 204.241187] [] iwl_mvm_rs_tx_status+0x2ec/0x8c0 [iwlmvm]
[ 204.241239] [] iwl_mvm_tx_reclaim+0x2e0/0x3d0 [iwlmvm]
[ 204.241291] [] iwl_mvm_rx_ba_notif+0x160/0x1d0 [iwlmvm]
[ 204.241341] [] iwl_mvm_rx_common+0x6c/0x2d8 [iwlmvm]
[ 204.241391] [] iwl_mvm_rx+0x7c/0x88 [iwlmvm]
[ 204.241419] [] iwl_pcie_rx_handle+0x270/0x768 [iwlwifi]
[ 204.241444] [] iwl_pcie_irq_handler+0x17c/0x788 [iwlwifi]
[ 204.241452] [] irq_thread_fn+0x30/0x80
[ 204.241455] [] irq_thread+0x11c/0x1a8
[ 204.241459] [] kthread+0xec/0xf0
[ 204.241464] [] ret_from_fork+0x10/0x30
[10235.258719] iwlwifi 0000:01:00.0: Queue 16 stuck for 10000 ms.
[10235.328872] iwlwifi 0000:01:00.0: Current SW read_ptr 180 write_ptr 34
[10235.407295] iwl data: 00000000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
[10235.512672] iwlwifi 0000:01:00.0: FH TRBs(0) = 0xaafc904f
[10235.578491] iwlwifi 0000:01:00.0: FH TRBs(1) = 0x801020bc
[10235.643394] iwlwifi 0000:01:00.0: FH TRBs(2) = 0x93b65654
[10235.708252] iwlwifi 0000:01:00.0: FH TRBs(3) = 0x8030005c
[10235.773131] iwlwifi 0000:01:00.0: FH TRBs(4) = 0x909c1c53
[10235.837994] iwlwifi 0000:01:00.0: FH TRBs(5) = 0x8050407c
[10235.902961] iwlwifi 0000:01:00.0: FH TRBs(6) = 0x25b870b8
[10235.968097] iwlwifi 0000:01:00.0: FH TRBs(7) = 0x0070904b
[10236.033066] iwlwifi 0000:01:00.0: Q 0 is active and mapped to fifo 3 ra_tid 0x0000 [95,95]
[10236.132497] iwlwifi 0000:01:00.0: Q 1 is active and mapped to fifo 2 ra_tid 0x0000 [0,0]
[10236.229762] iwlwifi 0000:01:00.0: Q 2 is active and mapped to fifo 1 ra_tid 0x0000 [189,189]
[10236.331402] iwlwifi 0000:01:00.0: Q 3 is active and mapped to fifo 0 ra_tid 0x0000 [0,0]
[10236.425518] iwlwifi 0000:01:00.0: Q 4 is active and mapped to fifo 5 ra_tid 0x0000 [125,125]
[10236.529720] iwlwifi 0000:01:00.0: Q 5 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[10236.629181] iwlwifi 0000:01:00.0: Q 6 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[10236.728416] iwlwifi 0000:01:00.0: Q 7 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[10236.827773] iwlwifi 0000:01:00.0: Q 8 is active and mapped to fifo 3 ra_tid 0x0000 [0,0]
[10236.925057] iwlwifi 0000:01:00.0: Q 9 is active and mapped to fifo 7 ra_tid 0x0000 [76,76]
[10237.024408] iwlwifi 0000:01:00.0: Q 10 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[10237.124806] iwlwifi 0000:01:00.0: Q 11 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[10237.225205] iwlwifi 0000:01:00.0: Q 12 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[10237.325604] iwlwifi 0000:01:00.0: Q 13 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[10237.410426] iwlwifi 0000:01:00.0: Q 14 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[10237.525985] iwlwifi 0000:01:00.0: Q 15 is active and mapped to fifo 5 ra_tid 0x0000 [0,0]
[10237.624306] iwlwifi 0000:01:00.0: Q 16 is active and mapped to fifo 1 ra_tid 0x0000 [180,36]
[10237.725730] iwlwifi 0000:01:00.0: Q 17 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[10237.826132] iwlwifi 0000:01:00.0: Q 18 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[10237.911926] iwlwifi 0000:01:00.0: Q 19 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[10238.010623] iwlwifi 0000:01:00.0: Q 20 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[10238.110614] iwlwifi 0000:01:00.0: Q 21 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[10238.114535] WR pointer moved while flushing 45 → 128
[10238.114598] ------------[ cut here ]------------
[10238.114631] WARNING: CPU: 3 PID: 4691 at /home/linux/top_dir/kernel_sources/Linux_for_Tegra/source/public/kernel/kernel-4.9/drivers/net/wireless/intel/iwlwifi/pcie/trans.c:2099 iwl_trans_pcie_wait_txq_empty+0x190/0x200 [iwlwifi]
[10238.114674] Modules linked in: ipt_MASQUERADE nf_nat_masquerade_ipv4 xt_conntrack ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter nf_nat_h323 nf_conntrack_h323 nf_nat_pptp nf_nat_proto_gre nf_conntrack_pptp nf_conntrack_proto_gre nf_nat_tftp nf_conntrack_tftp nf_nat_sip nf_conntrack_sip nf_nat_irc nf_conntrack_irc nf_nat_ftp nf_conntrack_ftp iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack fuse overlay bnep zram userspace_alert nvgpu iwlmvm mac80211 ftdi_sio btusb btrtl btbcm btintel iwlwifi cfg80211 spidev ar0330(O) bluedroid_pm ip_tables x_tables
[10238.114678] CPU: 3 PID: 4691 Comm: wpa_supplicant Tainted: G W O 4.9.201 #1
[10238.114680] Hardware name: NVIDIA Jetson Nano Developer Kit (DT)
[10238.114681] task: ffffffc0f07baa00 task.stack: ffffffc0f07c4000
[10238.114704] PC is at iwl_trans_pcie_wait_txq_empty+0x190/0x200 [iwlwifi]
[10238.114725] LR is at iwl_trans_pcie_wait_txq_empty+0x190/0x200 [iwlwifi]
[10238.114727] pc : [] lr : [] pstate: 20400045
[10238.114728] sp : ffffffc0f07c7720
[10238.114731] x29: ffffffc0f07c7720 x28: ffffffc0f05e4190
[10238.114734] x27: 0000000000000002 x26: ffffffc0e7440238
[10238.114737] x25: ffffffc0e7447e30 x24: 000000000001000f
[10238.114740] x23: ffffffc0e7447238 x22: 000000000000002d
[10238.114743] x21: ffffff8009e76980 x20: 000000010025eafd
[10238.114745] x19: 00000000ffffff92 x18: 0000000000000001
[10238.114748] x17: 0000000000000002 x16: 0000000000000000
[10238.114750] x15: ffffffffffffffff x14: ffffff800a15add8
[10238.114753] x13: ffffff800a15aa21 x12: ffffff8009e94000
[10238.114755] x11: 0000000000000000 x10: ffffff800a15a000
[10238.114758] x9 : 0000000000000000 x8 : ffffffc0fef96fd3
[10238.114760] x7 : 0000000000000000 x6 : 000000275d7a2136
[10238.114762] x5 : 0000000000000000 x4 : 0000000000000000
[10238.114765] x3 : ffffffffffffffff x2 : 00000040f57ae000
[10238.114767] x1 : ffffffc0f07baa00 x0 : 0000000000000029
[10238.114769] —[ end trace d5ac9942a3b68e72 ]—
[10238.114770] Call trace:
[10238.114794] [] iwl_trans_pcie_wait_txq_empty+0x190/0x200 [iwlwifi]
[10238.114848] [] iwl_mvm_sta_tx_agg_flush+0xfc/0x1f8 [iwlmvm]
[10238.114894] [] iwl_mvm_mac_ampdu_action+0x1e0/0x460 [iwlmvm]
[10238.114998] [] drv_ampdu_action+0x60/0x210 [mac80211]
[10238.115093] [] ___ieee80211_stop_tx_ba_session+0xf4/0x240 [mac80211]
[10238.115182] [] __ieee80211_stop_tx_ba_session+0x40/0x60 [mac80211]
[10238.115274] [] ieee80211_sta_tear_down_BA_sessions+0x4c/0x90 [mac80211]
[10238.115367] [] __sta_info_destroy_part1+0x48/0x5f8 [mac80211]
[10238.115461] [] __sta_info_destroy+0x20/0x48 [mac80211]
[10238.115555] [] sta_info_destroy_addr_bss+0x38/0x58 [mac80211]
[10238.115651] [] ieee80211_del_station+0x2c/0x50 [mac80211]
[10238.115737] [] nl80211_del_station+0xbc/0x288 [cfg80211]
[10238.115744] [] genl_family_rcv_msg+0x2e4/0x3d0
[10238.115747] [] genl_rcv_msg+0x80/0xd8
[10238.115750] [] netlink_rcv_skb+0xa8/0xf0
[10238.115753] [] genl_rcv+0x3c/0x50
[10238.115755] [] netlink_unicast+0x188/0x218
[10238.115758] [] netlink_sendmsg+0x2e0/0x340
[10238.115762] [] sock_sendmsg+0x4c/0x68
[10238.115764] [] ___sys_sendmsg+0x2a8/0x2c0
[10238.115767] [] __sys_sendmsg+0x54/0x98
[10238.115770] [] SyS_sendmsg+0x38/0x50
[10238.115775] [] el0_svc_naked+0x34/0x38
[10238.579625] iwlwifi 0000:01:00.0: Q 22 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[10238.679865] iwlwifi 0000:01:00.0: Q 23 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[10238.780238] iwlwifi 0000:01:00.0: Q 24 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[10238.880611] iwlwifi 0000:01:00.0: Q 25 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[10238.981008] iwlwifi 0000:01:00.0: Q 26 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[10239.081411] iwlwifi 0000:01:00.0: Q 27 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[10239.182069] iwlwifi 0000:01:00.0: Q 28 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[10239.282485] iwlwifi 0000:01:00.0: Q 29 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[10239.382895] iwlwifi 0000:01:00.0: Q 30 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[10239.471564] iwlwifi 0000:01:00.0: Microcode SW error detected. Restarting 0x2000000.
[10239.576488] iwlwifi 0000:01:00.0: CSR values:
[10239.629650] iwlwifi 0000:01:00.0: (2nd byte of CSR_INT_COALESCING is CSR_INT_PERIODIC_REG)
[10239.728760] iwlwifi 0000:01:00.0: CSR_HW_IF_CONFIG_REG: 0X00c89000
[10239.798061] iwlwifi 0000:01:00.0: CSR_INT_COALESCING: 0X00000040
[10239.880849] iwlwifi 0000:01:00.0: CSR_INT: 0X00000000
[10239.962288] iwlwifi 0000:01:00.0: CSR_INT_MASK: 0X00000000
[10240.045857] iwlwifi 0000:01:00.0: CSR_FH_INT_STATUS: 0X00000000
[10240.119468] iwlwifi 0000:01:00.0: CSR_GPIO_IN: 0X00000010
[10240.207242] iwlwifi 0000:01:00.0: CSR_RESET: 0X00000000
[10240.293182] iwlwifi 0000:01:00.0: CSR_GP_CNTRL: 0X08040005
[10240.363202] iwlwifi 0000:01:00.0: CSR_HW_REV: 0X00000230
[10240.444353] iwlwifi 0000:01:00.0: CSR_EEPROM_REG: 0Xd55555d5
[10240.525646] iwlwifi 0000:01:00.0: CSR_EEPROM_GP: 0Xd55555d5
[10240.606844] iwlwifi 0000:01:00.0: CSR_OTP_GP_REG: 0Xd55555d5
[10240.688145] iwlwifi 0000:01:00.0: CSR_GIO_REG: 0X001f0046
[10240.769955] iwlwifi 0000:01:00.0: CSR_GP_UCODE_REG: 0X00000000
[10240.854550] iwlwifi 0000:01:00.0: CSR_GP_DRIVER_REG: 0X00000000
[10240.937521] iwlwifi 0000:01:00.0: CSR_UCODE_DRV_GP1: 0X00000000
[10241.028833] iwlwifi 0000:01:00.0: CSR_UCODE_DRV_GP2: 0X00000000
[10241.110326] iwlwifi 0000:01:00.0: CSR_LED_REG: 0X00000060
[10241.190721] iwlwifi 0000:01:00.0: CSR_DRAM_INT_TBL_REG: 0X8816dac9
[10241.263853] iwlwifi 0000:01:00.0: CSR_GIO_CHICKEN_BITS: 0X07800200
[10241.344222] iwlwifi 0000:01:00.0: CSR_ANA_PLL_CFG: 0Xd55555d5
[10241.426399] iwlwifi 0000:01:00.0: CSR_MONITOR_STATUS_REG: 0Xc03803c0
[10241.511902] iwlwifi 0000:01:00.0: CSR_HW_REV_WA_REG: 0X0001001a
[10241.585378] iwlwifi 0000:01:00.0: CSR_DBG_HPET_MEM_REG: 0Xffff0010
[10241.666706] iwlwifi 0000:01:00.0: FH register values:
[10241.731926] iwlwifi 0000:01:00.0: FH_RSCSR_CHNL0_STTS_WPTR_REG: 0X1747a900
[10241.825628] iwlwifi 0000:01:00.0: FH_RSCSR_CHNL0_RBDCB_BASE_REG: 0X01687850
[10241.917657] iwlwifi 0000:01:00.0: FH_RSCSR_CHNL0_WPTR: 0X00000070
[10242.008097] iwlwifi 0000:01:00.0: FH_MEM_RCSR_CHNL0_CONFIG_REG: 0X00801054
[10242.101345] iwlwifi 0000:01:00.0: FH_MEM_RSSR_SHARED_CTRL_REG: 0X000000fc
[10242.192698] sched: RT throttling activated for rt_rq ffffffc0fefc0f28 (cpu 1)
potential CPU hogs:
irq/408-iwlwifi (3781)
[10242.242476] iwlwifi 0000:01:00.0: FH_MEM_RSSR_RX_STATUS_REG: 0X03030000
[10242.333717] iwlwifi 0000:01:00.0: FH_MEM_RSSR_RX_ENABLE_ERR_IRQ2DRV: 0X00000000
[10242.424839] iwlwifi 0000:01:00.0: FH_TSSR_TX_STATUS_REG: 0X07ff0001
[10242.516012] iwlwifi 0000:01:00.0: FH_TSSR_TX_ERROR_REG: 0X00000000
[10242.607505] iwlwifi 0000:01:00.0: Start IWL Error Log Dump:
[10242.658861] iwlwifi 0000:01:00.0: Status: 0x00000000, count: 6
[10242.739193] iwlwifi 0000:01:00.0: Loaded firmware version: 22.391740.0
[10242.822297] iwlwifi 0000:01:00.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN
[10242.906012] iwlwifi 0000:01:00.0: 0x00000230 | trm_hw_status0
[10242.975134] iwlwifi 0000:01:00.0: 0x00000000 | trm_hw_status1
[10243.050622] iwlwifi 0000:01:00.0: 0x0000E258 | branchlink2
[10243.116506] iwlwifi 0000:01:00.0: 0x00027324 | interruptlink1
[10243.185645] iwlwifi 0000:01:00.0: 0x00000A10 | interruptlink2
[10243.252577] iwlwifi 0000:01:00.0: 0x00000000 | data1
[10243.314123] iwlwifi 0000:01:00.0: 0x00000080 | data2
[10243.373827] iwlwifi 0000:01:00.0: 0x07830000 | data3
[10243.422439] iwlwifi 0000:01:00.0: 0x5100D18D | beacon time
[10243.499198] iwlwifi 0000:01:00.0: 0x607C6A29 | tsf low
[10243.561013] iwlwifi 0000:01:00.0: 0x00000002 | tsf hi
[10243.621794] iwlwifi 0000:01:00.0: 0x00000000 | time gp1
[10243.684648] iwlwifi 0000:01:00.0: 0x607C6A41 | time gp2
[10243.747515] iwlwifi 0000:01:00.0: 0x00000000 | uCode revision type
[10243.821832] iwlwifi 0000:01:00.0: 0x00000016 | uCode version major
[10243.896148] iwlwifi 0000:01:00.0: 0x0005FA3C | uCode version minor
[10243.970507] iwlwifi 0000:01:00.0: 0x00000230 | hw version
[10244.035437] iwlwifi 0000:01:00.0: 0x00C89000 | board version
[10244.103493] iwlwifi 0000:01:00.0: 0x0961014E | hcmd
[10244.160750] iwlwifi 0000:01:00.0: 0x24022000 | isr0
[10244.220510] iwlwifi 0000:01:00.0: 0x00800000 | isr1
[10244.277382] iwlwifi 0000:01:00.0: 0x08001802 | isr2
[10244.322809] iwlwifi 0000:01:00.0: 0x0041FCC0 | isr3
[10244.386720] iwlwifi 0000:01:00.0: 0x00000000 | isr4
[10244.441147] iwlwifi 0000:01:00.0: 0x00000110 | last cmd Id
[10244.513701] iwlwifi 0000:01:00.0: 0x00000000 | wait_event
[10244.584404] iwlwifi 0000:01:00.0: 0x00000080 | l2p_control
[10244.650440] iwlwifi 0000:01:00.0: 0x00010030 | l2p_duration
[10244.717501] iwlwifi 0000:01:00.0: 0x0000003F | l2p_mhvalid
[10244.783498] iwlwifi 0000:01:00.0: 0x00800000 | l2p_addr_match
[10244.852103] iwlwifi 0000:01:00.0: 0x0000000F | lmpm_pmg_sel
[10244.919280] iwlwifi 0000:01:00.0: 0x25091923 | timestamp
[10244.983201] iwlwifi 0000:01:00.0: 0x00347080 | flow_handler
[10245.050325] iwlwifi 0000:01:00.0: Start IWL Error Log Dump:
[10245.117353] iwlwifi 0000:01:00.0: Status: 0x00000000, count: 7
[10245.187526] iwlwifi 0000:01:00.0: 0x00000070 | ADVANCED_SYSASSERT
[10245.260588] iwlwifi 0000:01:00.0: 0x00000000 | umac branchlink1
[10245.331857] iwlwifi 0000:01:00.0: 0xC0082F64 | umac branchlink2
[10245.402839] iwlwifi 0000:01:00.0: 0xC0081000 | umac interruptlink1
[10245.461344] iwlwifi 0000:01:00.0: 0xC0081000 | umac interruptlink2
[10245.543783] iwlwifi 0000:01:00.0: 0x00000800 | umac data1
[10245.615670] iwlwifi 0000:01:00.0: 0xC0081000 | umac data2
[10245.680620] iwlwifi 0000:01:00.0: 0xDEADBEEF | umac data3
[10245.743596] iwlwifi 0000:01:00.0: 0x00000016 | umac major
[10245.810144] iwlwifi 0000:01:00.0: 0x0005FA3C | umac minor
[10245.872608] iwlwifi 0000:01:00.0: 0xC0886280 | frame pointer
[10245.942840] iwlwifi 0000:01:00.0: 0xC0886280 | stack pointer
[10246.010927] iwlwifi 0000:01:00.0: 0x0961014E | last host cmd
[10246.075375] iwlwifi 0000:01:00.0: 0x00000000 | isr status reg
[10246.147768] ieee80211 phy0: Hardware restart was requested
[10246.698766] iwlwifi 0000:01:00.0: L1 Disabled - LTR Enabled
[10246.699025] iwlwifi 0000:01:00.0: L1 Disabled - LTR Enabled
[10246.814003] iwlwifi 0000:01:00.0: L1 Disabled - LTR Enabled
[10246.814278] iwlwifi 0000:01:00.0: L1 Disabled - LTR Enabled
2. Boot-Time Logs
Every time the system boots, we observe the following messages before the firmware eventually loads:
[ 16.227486] iwlwifi: unknown parameter ‘fw_name’ ignored
[ 16.275532] iwlwifi 0000:01:00.0: enabling device (0000 → 0002)
[ 16.311932] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-26.ucode failed with error -2
[ 16.322115] iwlwifi 0000:01:00.0: Falling back to user helper
[ 16.754843] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-25.ucode failed with error -2
[ 16.764123] iwlwifi 0000:01:00.0: Falling back to user helper
[ 16.810364] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-24.ucode failed with error -2
[ 16.821256] iwlwifi 0000:01:00.0: Falling back to user helper
[ 16.826542] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-23.ucode failed with error -2
[ 16.826545] iwlwifi 0000:01:00.0: Falling back to user helper
[ 16.840120] iwlwifi 0000:01:00.0: loaded firmware version 22.391740.0 op_mode iwlmvm
[ 17.024268] iwlwifi 0000:01:00.0: Detected Intel(R) Dual Band Wireless AC 8265, REV=0x230
[ 17.034084] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 17.040659] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 17.174369] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type iwlwifi
[ 28.402593] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 28.403111] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 28.532962] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 28.533399] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
The module is supposed to work on Jetson Nano developer kit with default Jetpack release. Would suggest try latest Jetpack 4.6.6
Hi @DaneLLL, The OS + hardware is in production.
and it was already working since last 3 years. except updating and flashing the kernel, what’s the right way?
Maybe that’s the chip issue. We’re not able to confirm.
