When I run the command nvcc --version or nvidia-smi it return command not found
I’m on JetPack 4.6.1 which is supposed to have CUDA toolkit built-in, how do I resolve this & check CUDA compiler version on the Nano??
nvidia-smi is not available on Jetpack4 and JetPack5.
It is only available on JetPack 6 which only supports the Orin series.
How about the nvcc --version command?
How do I resolve the nvcc: command not found message ?
nvcc is part of CUDA library.
You can find it in /usr/local/cuda-[ver]/bin.
For example:
$ /usr/local/cuda/bin/nvcc --version
