I reflashed jetson xavier nx using command line interface. Doubt that sdk components like cuda installed along with that. If so how will i check that. When i give nvcc --version in command promt giving that nvcc not found
you could use dpkg:
$ dpkg -l | grep nvcc
ii cuda-nvcc-11-4 11.4.315-1 arm64 CUDA nvcc
if you want to install the CUDA tools, you could use:
sudo apt install -y nvidia-jetpack
$ dpkg -l | grep jetpack
ii libnvidia-container0:arm64 0.11.0+jetpack arm64 NVIDIA container runtime library
ii nvidia-jetpack-runtime 5.1.1-b56 arm64 NVIDIA Jetpack runtime Meta Package
beware of disk space during that install though, packages are quite large and can easily fill your disk if you boot from eMMC which is only16GB.
