Jetson Nano MCP2515 CAN Interface
Hi
I have seen a new post in the following link
[Jetson nano and mcp2515 can module - #295 by shgarg]
as the solution for interfacing mcp2515 with jetson Nano in post 295.
After Executing Step Number 5 and running Jetson IO Tool is not launching.
i am using jetpack 32.5.1
jetson IO Tool is launching without any problems if the 2 dtbo files remains in the /boot folder
  1. tegra210-p3448-0000-p3449-0000-a01-mcp251x.dtbo
  2. tegra210-p3448-0000-p3449-0000-a02-mcp251x.dtbo
When removing the above mentioned 2 dtbo files are removed and copying the generated jetson-mcp251x.dtbo file as mentioned in the step 5 of the forum jetson IO Tool is not opening.It just closes all of sudden.
Please help me to solve this issue
Thanks and Regards
Note: Also attached screenshot of the Post 295
Sorry for the late response, is this still an issue to support?
