- The ifconfig output for host:
docker0 Link encap:Ethernet HWaddr 02:42:7e:c9:a1:58
inet addr:172.17.0.1 Bcast:172.17.255.255 Mask:255.255.0.0
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
enp0s31f6 Link encap:Ethernet HWaddr 54:bf:64:75:a6:18
inet addr:192.168.2.102 Bcast:192.168.2.255 Mask:255.255.255.0
inet6 addr: fe80::d801:f176:ba87:1eb5/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:36780256 errors:0 dropped:0 overruns:0 frame:0
TX packets:9441127 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:12011817570 (12.0 GB) TX bytes:8559315398 (8.5 GB)
Interrupt:16 Memory:ef180000-ef1a0000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:25444 errors:0 dropped:0 overruns:0 frame:0
TX packets:25444 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:2726141 (2.7 MB) TX bytes:2726141 (2.7 MB)
lxcbr0 Link encap:Ethernet HWaddr 00:16:3e:00:00:00
inet addr:10.0.3.1 Bcast:0.0.0.0 Mask:255.255.255.0
- The route output for host:
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default 192.168.2.1 0.0.0.0 UG 100 0 0 enp0s31f6
10.0.3.0 * 255.255.255.0 U 0 0 0 lxcbr0
link-local * 255.255.0.0 U 1000 0 0 lxcbr0
172.17.0.0 * 255.255.0.0 U 0 0 0 docker0
192.168.2.0 * 255.255.255.0 U 100 0 0 enp0s31f6
- The ifconfig output for Nano:
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.2.187 netmask 255.255.255.0 broadcast 192.168.2.255
inet6 fe80::36:d228:6577:6d5a prefixlen 64 scopeid 0x20<link>
ether 00:04:4b:e5:d8:f8 txqueuelen 1000 (Ethernet)
RX packets 48959 bytes 3892170 (3.8 MB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 120 bytes 14885 (14.8 KB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 149 base 0xe000
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1 (Local Loopback)
RX packets 163 bytes 14235 (14.2 KB)
TX packets 163 bytes 14235 (14.2 KB)
rndis0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether ce:66:f9:59:de:31 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
usb0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether ce:66:f9:59:de:33 txqueuelen 1000 (Ethernet)
- And the route output for Nano:
default _gateway 0.0.0.0 UG 100 0 0 eth0
link-local 0.0.0.0 255.255.0.0 U 1000 0 0 eth0
192.168.2.0 0.0.0.0 255.255.255.0 U 100 0 0 eth0
Besides, we have been working with modified kernels. There is no out-of-box support for SD card, for which we had to use a patch, please find below.
diff --git a/hardware/nvidia/platform/t210/common/kernel-dts/t210-common-platforms/tegra210-p2530-common.dtsi b/hardware/nvidia/platform/t210/common/kernel-dts/t210-common-platforms/tegra210-p2530-common.dtsi
--- a/hardware/nvidia/platform/t210/common/kernel-dts/t210-common-platforms/tegra210-p2530-common.dtsi 2019-09-18 13:21:25.000000000 +0200
+++ b/hardware/nvidia/platform/t210/common/kernel-dts/t210-common-platforms/tegra210-p2530-common.dtsi 2019-09-18 13:26:22.723470000 +0200
@@ -131,7 +131,7 @@
uhs-mask = <0x1c>;
power-off-rail;
nvidia,update-pinctrl-settings;
- status = "disabled";
+ status = "okay";
sdhci@700b0200 {
diff --git a/hardware/nvidia/platform/t210/porg/kernel-dts/porg-plugin-manager/tegra210-porg-plugin-manager.dtsi b/hardware/nvidia/platform/t210/porg/kernel-dts/porg-plugin-manager/tegra210-porg-plugin-manager.dtsi
--- a/hardware/nvidia/platform/t210/porg/kernel-dts/porg-plugin-manager/tegra210-porg-plugin-manager.dtsi 2019-09-18 13:21:25.000000000 +0200
+++ b/hardware/nvidia/platform/t210/porg/kernel-dts/porg-plugin-manager/tegra210-porg-plugin-manager.dtsi 2019-09-18 13:28:08.251948000 +0200
@@ -313,7 +313,8 @@
override@1 {
target = <&sdhci2>;
_overlay_ {
- vmmc-supply = <&max77620_ldo6>;
+ status = "okay";
+ vqmmc-supply = <&max77620_ldo6>;
no-sdio;
no-mmc;
sd-uhs-sdr104;
diff --git a/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-porg-p3448-common.dtsi b/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-porg-p3448-common.dtsi
--- a/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-porg-p3448-common.dtsi 2019-09-18 13:21:25.000000000 +0200
+++ b/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-porg-p3448-common.dtsi 2019-09-18 13:30:00.344454000 +0200
@@ -250,9 +250,14 @@
sdhci@700b0400 {
+ status = "okay";
/delete-property/ keep-power-in-suspend;
/delete-property/ non-removable;
+ mmc-ddr-1_8v;
+ mmc-ocr-mask = <3>;
+ uhs-mask = <0x0>;
+ max-clk-limit = <400000>;
+ tap-delay = <3>;
sdhci@700b0200 { /* SDMMC2 for Wifi */
It was discussed here: https://devtalk.nvidia.com/default/topic/1062120/jetson-nano/microsd-card-not-detected-on-jetson-nano-production-module/post/5380197/#5380197
The thing is, it was only after removing this patch that the long SSH delays were gone. I really have no clue how it is possible, but we would be needing the patch.
Could you please advise regarding this?
