I tried to ssh into my Jetson Nano from my PC (running Ubuntu 18.04) using WiFi on the same network a few days ago and it worked. However, when I tried doing it today, I’m no longer able to do so. I connected an EdiMax WiFi adapter to the Nano and turned on WiFi on my personal hotspot and made sure that my computer that I was sshing into the Nano was also on the same network.
When I tried to ping the IP address of the Jetson Nano, it returns Destination Host Unreachable. When I tried to ssh in, it says no route to host. When I traceroute the Nano IP address, it also says that host is unavailable (!H). If someone could point out how I can rectify this, I’d be very grateful. Thank you!
The above says that whatever the problem is that it is out of the hands of the Jetson. It is still possibly a fault with the Jetson if for example the interface providing the connection went down, but anything else tends to be part of the local network (or DNS if using that). On both host PC and Jetson these commands would provide more information:
