I’ve been trying to connect to the Jetson board through SSH with no luck.
I created a wifi hostspot with the host PC on which the Nano is connected thanks to a USB Wifi adapter.
The very first connection was succesful and since then I cannot make it work anymore (the Nano is still connected).
Here are some things that might be useful :
$ssh -vvv mpariente@192.168.55.1
OpenSSH_7.6p1 Ubuntu-4ubuntu0.3, OpenSSL 1.0.2n 7 Dec 2017
debug1: Reading configuration data /home/mparient/.ssh/config
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: Applying options for *
debug2: resolving "192.168.55.1" port 22
debug2: ssh_connect_direct: needpriv 0
debug1: Connecting to 192.168.55.1 [192.168.55.1] port 22.
$ nmap 192.168.55.1
Starting Nmap 7.60 ( https://nmap.org ) at 2020-01-09 12:05 CET
Note: Host seems down. If it is really up, but blocking our ping probes, try -Pn
Nmap done: 1 IP address (0 hosts up) scanned in 3.03 seconds
And, when I’m on the Nano, ssh localhost work.
Thanks in advance,
Manu
