When I power up the Jetson Nano and then wait for over a minute and try to ssh, it doesn’t let me connect to the Jetson Nano. ssh: connect to host 192.168.1.53 port 22: Connection refused
Edit: I have an usb wifi extender
Running Jetson nano (4GB) w/ image “jetson-nano-jp451-sd-card-image”. I first used a keyboard, mouse and monitor to set the system up; subsequently I have had no problem accessing the system with ‘ssh’.
Are you trying to set up without a keyboard, mouse and monitor? Or is this a post-setup question?
I’ve had already set it up, but whenever I boot it with only the usbc power supply and the usb wifi extender I can’t ssh it.
Ok, it was a dynamic IP problem, sorry, and thanks for your help.
Ah, good – glad you got it.
