Hello. I need to access the U-Boot environment from Linux userspace on the Jetson Nano. I can’t seem to find the fw_env.config that the U-Boot tools “fw_printenv” and “fw_setenv” require to access and modify the bootloader environment.
I get the following error:
root@jetson-nano:/tmp# ./fw_printenv
Cannot access MTD device /dev/mmcblk0boot1: No such file or directory
How can I access the U-Boot environment on the Jetson Nano? Thank you.
For TX1 and TX2 - these were under /dev/mmcblk0boot1:
ubuntu@ip-172-31-23-71:~/Desktop/jetson-yocto/build/tmp/deploy/images/jetson-nano$ cat /home/ubuntu/Desktop/jetson-yocto/layers/meta-tegra/recipes-bsp/u-boot/files/tegra210/fw_env.config
# Jetson-TX1 dev kit puts U-Boot params in eMMC boot1 partition
/dev/mmcblk0boot1 0x3fe000 0x2000
ubuntu@ip-172-31-23-71:~/Desktop/jetson-yocto/build/tmp/deploy/images/jetson-nano$ cat /home/ubuntu/Desktop/jetson-yocto/layers/meta-tegra/recipes-bsp/u-boot/files/tegra186/fw_env.config
# Jetson-TX2 dev kit puts U-Boot params in eMMC boot1 partition
FDisk shows the following:
Device Start End Sectors Size Type
/dev/mmcblk0p1 24576 33554398 33529823 16G Linux filesystem
/dev/mmcblk0p2 2048 2303 256 128K Linux filesystem
/dev/mmcblk0p3 4096 4991 896 448K Linux filesystem
/dev/mmcblk0p4 6144 7295 1152 576K Linux filesystem
/dev/mmcblk0p5 8192 8319 128 64K Linux filesystem
/dev/mmcblk0p6 10240 10623 384 192K Linux filesystem
/dev/mmcblk0p7 12288 13439 1152 576K Linux filesystem
/dev/mmcblk0p8 14336 14463 128 64K Linux filesystem
/dev/mmcblk0p9 16384 17663 1280 640K Linux filesystem
/dev/mmcblk0p10 18432 19327 896 448K Linux filesystem
/dev/mmcblk0p11 20480 20735 256 128K Linux filesystem
/dev/mmcblk0p12 22528 22687 160 80K Linux filesystem
/dev/mmcblk0p13 33554432 67186687 33632256 16G Linux filesystem
Partition table entries are not in disk order.
And Parted shows the following:
root@jetson-nano:/tmp# parted /dev/mmcblk0
GNU Parted 3.2
Using /dev/mmcblk0
Welcome to GNU Parted! Type 'help' to view a list of commands.
(parted) print
Model: SD SR128 (sd/mmc)
Disk /dev/mmcblk0: 128GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
2 1049kB 1180kB 131kB TBC
3 2097kB 2556kB 459kB RP1
4 3146kB 3736kB 590kB EBT
5 4194kB 4260kB 65.5kB WB0
6 5243kB 5439kB 197kB BPF
7 6291kB 6881kB 590kB TOS
8 7340kB 7406kB 65.5kB EKS
9 8389kB 9044kB 655kB LNX
10 9437kB 9896kB 459kB DTB
11 10.5MB 10.6MB 131kB RP4
12 11.5MB 11.6MB 81.9kB BMP
1 12.6MB 17.2GB 17.2GB ext4 APP
13 17.2GB 34.4GB 17.2GB ext4 primary
