Jetson Nano UART Pinout
Hi there,
I need to 2 seperate UART lines but I found only one.
When I looked at the Jetson Nano 4GB board, I saw 2 UART lines. One is under the heat-sink, the other is in the J41-pins header region. Why is the 2nd UART line not showing anywhere? Am I seeing it wrong?
hello kullanici885,
please access Jetson Nano Product Design Guide, Jetson Nano brings three UARTs out to the main connector. you should see [Figure 11-5. Jetson Nano UART Connections] for reference,
thanks
Thank you :)
