使用jetson nano Ubuntu18.04 部署yolov5时,生成yolov5s.engine文件报错
Description
Environment
Ubuntu Version: 18.04
Python Version (if applicable): 3.6
PyTorch Version (if applicable): 1.8
YoLov5 Version: V5
Relevant Files
sudo ./yolov5 -s yolov5s.wts yolov5s.engine s
Loading weights: yolov5s.wts
[11/10/2021-20:28:57] [E] [TRT] Parameter check failed at: …/builder/Network.cpp::addScale::482, condition: shift.count > 0 ? (shift.values != nullptr) : (shift.values == nullptr)
yolov5: /home/nano/tensorrtx/yolov5/common.hpp:155: nvinfer1::IScaleLayer* addBatchNorm2d(nvinfer1::INetworkDefinition*, std::map<std::__cxx11::basic_string, nvinfer1::Weights>&, nvinfer1::ITensor&, std::__cxx11::string, float): Assertion `scale_1’ failed.
Aborted
This looks like a Jetson issue. Please refer to the below samlples in case useful.
For any further assistance, we recommend you to raise it to the respective platform from the below link
有解决吗我转换的时候也是这个错误sudo ./yolov5 -s yolov5l.wts yolov5l.engine l
Loading weights: yolov5l.wts
[12/27/2022-16:12:05] [E] [TRT] Parameter check failed at: …/builder/Network.cpp::addScale::482, condition: shift.count > 0 ? (shift.values != nullptr) : (shift.values == nullptr)
yolov5: /home/nvidia/yolov5/tensorrtx/yolov5/common.hpp:155: nvinfer1::IScaleLayer* addBatchNorm2d(nvinfer1::INetworkDefinition*, std::map<std::__cxx11::basic_string, nvinfer1::Weights>&, nvinfer1::ITensor&, std::__cxx11::string, float): Assertion `scale_1’ failed.
(3条消息) Jetson NX + yolov5 v5.0 + TensorRT加速+调用usb摄像头_无证驾驶梁嗖嗖的博客-CSDN博客
已经解决谢谢
