Jetson Nano Wifi - USB adapter/ Wifi Card with Antennas
Good day, I want to get the cheapest option for connecting my Jetson Nano to the internet. What are the specifications for the usb/card Wifi? Can I just get a usb wifi adapter from a local store here in South Africa?
And is wifi connection necessary for initial setup ?
We don’t have the suggestion for the Wifi card, you may do the search in forum to find what other people used or check Jetson Nano - eLinux.org to find the suitable one.
Good day, do you have a suggestion on a good usb wifi adapter that would work well for connection my jetson nano B01 dev kit to my laptop in order to communicate over ROS1?
This M.2 card on Amazon works great on my Jetson Nano. The only problem with this was that the SMA antennas are not supported by anything, and you won’t want to use it like that. I designed and printed a case for my Nano that supports them, but you could use film antennas since those wouldn’t need much support
https://www.amazon.com/dp/B07SGDRG34
USB adapters work too, such as this one:
However you need an internet connection to install the drivers necessary for this specific USB adapter (rtl88x2bu), whereas with an M.2 card you plug it in and it works.
