Jetson Nano Wifi 5 GHz Hardware recommendation
Hey there,
I would like to set up a 5GHz Wifi connection between two NVIDIA Jetson Nano in AP mode to stream video data.
I am looking for a USB wifi adapter that will work on a NVIDIA Jetson Nano as a client in a 5GHz connection.
My hardware setup consists of a NVIDIA Jetson Nano devKit and a Jetson Nano on the Leopard carrier board (LI-NANO-CB V1.2).
On the NVIDIA devKit a Lairid M.2 dual band card is used. This is intended to be the access point in the 5 GHz WLAN network.
The Jetson Nano on the Leopard carrier board will represent the client in the network connection. The Leopard carrier board has no M.2 interface so I need a WLAN USB adapter which i am searching for.
I have already done some research and found the following possible devices.
EW-7833UAC:
Driver package is usable for kernel version 2.6 -5.1. I currently use kernel version 4.9 on Nano. So it should fit…
Geekworm:
devices:
Wiki page with manual to install driver:
https://raspberrypiwiki.com/Wireless_USB_adapter
Does anyone have experience with these USB WLAN adapters or can tell me if Jetson works with one of these devices.
I had bad experiences with USB WLAN adapters in the past (not working drivers, 2.4 Ghz works but 5 Ghz does not).
Maybe someone here can help me or give a recommendation.
Thanks and best regards !
Please refer to Jetson Nano - eLinux.org
