Jetson nano wont boot
Hi! I have an jetson nano 4gb and it shows this when i try to boot the sd card. i tried all the solutions that i could find online..
also this method doesnt work for me. it shows no sdks
Which version of ubuntu host PC are you using there?
Jetson nano is a product that is quite old. So you could only use Ubuntu 18.04 host to flash it.
ok i tried again on an ubuntu 18.04 and the only option is 4.6.6.
So, what do i have to do to install the OS on the board? It also says Failed to load kernel modules when booting the sd card.. after that it shows that error in the image
can you help me please?
What is the current situation?
Does your sdkamnager work there or not?
I am not sure what does that mean “the only option is 4.6.6”.
Then just install Jetpack4.6.6.
Also, you better reading this post because I don’t really see any true NVIDIA Jetson Nano devkit since 2024.
Your case is probably not a NV devkit either.
