My Jetson Orin development kit will softly beep every 5 seconds. Evey time it does the fan moves a tiny bit in alternating directions but never actually spins. The fan very rarely spins on power up but it’s hard to reproduce. When the fan does work correctly the PWM/RPM values look fine. The beeping and no fan happens 95% of the time.
dmesg shows the following:
[ 113.239580] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 116.866354] pwm-tegra-tachometer 39c0000.tachometer: Tachometer Overflow is detected
[ 166.252189] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 181.796520] nvgpu: 17000000.ga10b railgate_enable_store:322 [INFO] railgate is disabled.
[ 219.437243] nvgpu: 17000000.ga10b railgate_enable_store:322 [INFO] railgate is disabled.
[ 229.241613] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 292.264264] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 355.284543] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 418.295162] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 481.293492] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 544.241156] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 583.607565] nvgpu: 17000000.ga10b railgate_enable_store:322 [INFO] railgate is disabled.
[ 585.045325] hot-surface-alert cooling state: 0 -> 1
[ 607.265140] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 670.287593] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 733.290311] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 796.241004] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
Jetson Power GUI: Fan RPM looks odd here…
I have tried the following and nothing will start the fan:
1: sudo /usr/bin/jetson_clocks --fan
2: rmmod pwm_fan; modprobe pwm_fan
Any help would be appreciated
