Dear sir,
Does Jetson Orin module support config pin to timer or capture function?we want to use timer to capture some sync singals。
many thanks
Dear sir,
many thanks
hello jianghai_huang,
may I know what’s the actual use-case.
please check Argus samples, for example, syncSensor
for demonstration.
thanks
Dear JerryChang,
we need capture cameras exposure signals and some Time synchronization signals,we have used up CAM_FRSYNC pins, but still need some capture pins,do you have document to introduce which pin support timer function.
thanks
may I understand your actual use-case.
for example, is this multi-cam use-case, and you would like to have synchronize capture frames?
Dear Jerry,
Yes, it is multi-cam use-case, we want catch frame signal of every cam.
thanks
for demonstration of two camera synchronization.
