Jetson Orin Nano Detection Issue
I have a Jetson orin nano which I can successfully flash using SDK Manager running on a Ubuntu 20 install (I can do this either to SDCard or NVME drive).
SDK manager detects the Jetson instantly when it is in forced recovery. Unfortunately I am having problems flashing the device from the command line as some of the script based checks don’t detect the device.
I have looked at the ‘lsusb’ results which correctly show the device connected on the host machine.
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 045e:00cb Microsoft Corp. Basic Optical Mouse v2.0
Bus 001 Device 007: ID 0955:7523 NVIDIA Corp. APX
Bus 001 Device 002: ID 1c4f:0015 SiGma Micro USB Keyboard
Bus 001 Device 005: ID 8087:0032 Intel Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
I am using the second to latest firmware 5.1.3 as opposed to 6. When I execute nvautoflash.sh along with the flag to show the board ID it states 0 devices connected.
*** Checking ONLINE mode … OK.
*** Checking target board connection … 0 connections found.
*** Error: No Jetson device found.
I am slightly confused why the Jetson is detected by SDK manager but not via the Nvidia scripts.
Can someone please advise what else I could try to progress with command line based flashing please.
What exact command did you run?
Put the full log here. Don’t crop it.
Hi Dave,
So the script I am running is basically doing the equivalent of downloading the two zip files and extracting them. So you end up with a folder called Linux_for_tegra which inside has all the config files and the example rootfs folder. I am navigating to the extracted /Linux_for_tegra folder and am executing
./nvautoflash.sh —print_boardid
I have also tried
sudo ./nvautoflash.sh —print_boardid
I have also tried
./nvautoflash.sh
They all produce the same output
dan@dan-System-Product-Name://install/Linux_for_Tegra$ sudo ./nvautoflash.sh --print_boardid
The board has been started in forced recovery mode and is connected via a USB C connection using the same cable used for the SDK Manager approach.
Follow all the steps here:
https://docs.nvidia.com/jetson/archives/r36.3/DeveloperGuide/IN/QuickStart.html
Yep so following those steps it worked and the device flashed successfully via the command line. Does that mean using nvautoflash.sh is an unreliable means of testing connections ?
A friend of mine has the same device (although they were using virtualisation for the Ubuntu host side vs a native Ubuntu box like I am) and it was seemingly reporting a connection.
Is there any strong reason you have to rely on nvautoflash.sh?
I don’t think it’s documented anywhere in the devloper guide.
lsusb should be enough.
No I don’t think so, I think someone had included it as a check. However if it’s been superseded or is old code no longer referenced I’ll suggest they remove it.
Thanks for your help.
