Jetson Orin Nano Dev kit - Juptyer-notebook lib error
Following the course for
** Aware Orin Nano isn’t support for this course, but i’m just exploring the possibility since that’s the device i got.
Jetson Orin Nano (dev kit)
Ubuntu 20.04
Jetpack 5.1.2
L4T 35.4.1
Seeing this error when running jupyterlab
OSError: libcurand.so.10: cannot open shared object file: No such file or directory
On my Jetson:
find ./ -name "libcurand.*"
the libs are install in /usr/local/cuda-11.4
./usr/local/cuda-11.4/targets/aarch64-linux/lib/libcurand.so.10.2.5.297
./usr/local/cuda-11.4/targets/aarch64-linux/lib/stubs/libcurand.so
jtop
Screenshot from 2024-01-01 13-53-08
which nvcc
/usr/local/cuda-11.4/bin/nvcc
Any easy solutions?
Hi @cedricyangks, how are you running JupyterLab? You can’t run the dlinano container that was built for JetPack 4 on JetPack 5, you will run into errors like that among other things.
Instead, (unofficially) you can try running those notebooks in a container that was built for JetPack 5 with JupyterLab, PyTorch, ect - like the l4t-ml container:
I believe there are some additional dependencies like jetcam that you would need to install in the container too.
Hi @dusty_nv , running juptyer lab via the shell script from the link
sudo docker run --runtime nvidia -it --rm --network host --volume ~/nvdli-data:/nvdli-nano/data --device /dev/video0 nvcr.io/nvidia/dli/dli-nano-ai:v2.0.2-r32.7.1
will try out the notebooks.
tyvm
