Jetson orin nano dev kit power switch
Hi, I’m using orin nano dev kit
i want to control power of orin nano dev kit by switch
i connect pin 5 and 6(J14) And make switch between 11 and 12
When i turn on the switch, LED turn on and fan works for just few seconds and it turned off
it power on well without all wiring
What should i do to control power by switch
That should work. Is it a push button switch?
yes it is push-hold switch, it works well in another application
And i just connect 11 and 12 pin by just wire, it works same as switch
“push-hold switch”? Means it will hold PWR_BTN to low always? If so, it would cause such issue. A tact switch is necessary.
Yes now i’m use push-hold switch, it hold PWR_BTN to low when i push switch
I’ll change it to tact switch
Thank you So much!
