Jetson Orin Nano - IMX219 not detected on JetPack 6 (Error -121)
karlikha, I have the same setup as you (Jetpack 6 running off SD card) and am encountering the same issue. I look forward your update as I’m not running Linux here either.
Hey, so I have try the SDK manager flash but unfortunately my board during the flashing is disconnection from computer and them connecting. The power suppla is okey, recovery mode on, and good usb c data transfer cable as well as usb port on motherboard of pc, i was trying to do taht on micro sd card and ssd, but I am using Virtualbox for ubuntu and that can be a issu but not sure. logs from sdk
0:02:35 SUMMARY: Multimedia API - target: Depends on failed component
10:02:35 SUMMARY: TensorRT on Target - target: Depends on failed component
10:02:35 SUMMARY: TensorRT Runtime - target: Depends on failed component
10:02:35 SUMMARY: CUDA Toolkit for L4T - target: Depends on failed component
10:02:35 SUMMARY: CUDA Runtime - target: Depends on failed component
10:02:35 SUMMARY: CuDNN on Target - target: Depends on failed component
10:02:35 SUMMARY: CuDNN Runtime - target: Depends on failed component
10:02:35 SUMMARY: OpenCV - target: Depends on failed component
10:02:35 SUMMARY: OpenCV Runtime - target: Depends on failed component
10:02:35 SUMMARY: CuPVA Runtime - target: Depends on failed component
10:02:35 SUMMARY: VPI on Target - target: Depends on failed component
10:02:35 SUMMARY: Nsight Systems - target: Depends on failed component
10:02:35 SUMMARY: Nsight Graphics - target: Depends on failed component
10:02:35 SUMMARY: Gstreamer - target: Depends on failed component
10:02:35 SUMMARY: DLA Compiler - target: Depends on failed component
10:02:35 SUMMARY: DateTime Target Setup - target: Depends on failed component
10:06:42 SUMMARY: Docker Environment Setup - target_image: Install completed successfully.
10:06:42 SUMMARY: Jetson Docker Image - target_image: Install completed successfully.
10:06:42 SUMMARY: Drivers for Jetson - target_image: Install completed successfully.
10:06:42 SUMMARY: File System and OS - target_image: Install completed successfully.
10:10:25 SUMMARY: Flash Jetson Linux - flash: No board connected. Please make sure the target hardware is connected and turned on, choose OK and RETRY.
10:10:25 SUMMARY: Multimedia API - target: Depends on failed component
10:10:25 SUMMARY: TensorRT on Target - target: Depends on failed component
10:10:25 SUMMARY: TensorRT Runtime - target: Depends on failed component
10:10:25 SUMMARY: CUDA Toolkit for L4T - target: Depends on failed component
10:10:25 SUMMARY: CUDA Runtime - target: Depends on failed component
10:10:25 SUMMARY: CuDNN on Target - target: Depends on failed component
10:10:25 SUMMARY: CuDNN Runtime - target: Depends on failed component
10:10:25 SUMMARY: OpenCV - target: Depends on failed component
10:10:25 SUMMARY: OpenCV Runtime - target: Depends on failed component
10:10:25 SUMMARY: CuPVA Runtime - target: Depends on failed component
10:10:25 SUMMARY: VPI on Target - target: Depends on failed component
10:10:25 SUMMARY: VPI Runtime - target: Depends on failed component
10:10:25 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta) - target: Depends on failed component
10:10:25 SUMMARY: Nsight Systems - target: Depends on failed component
10:10:25 SUMMARY: Nsight Graphics - target: Depends on failed component
10:10:25 SUMMARY: Gstreamer - target: Depends on failed component
10:10:25 SUMMARY: DLA Compiler - target: Depends on failed component
10:10:25 SUMMARY: DateTime Target Setup - target: Depends on failed component
No Idea Man I run out of the option last thing was to do flash withe SDK but that didn’t go well :(
Hi everyone,
I managed to install JetPack via SDK Manager, but without the SDK components because I ran into some problems during the installation. After the installation, I reconfigured the CSI port, but my camera is still not working. Any ideas? @JerryChang @selmaware
hello karlikha,
unfortunately, there’s known issue with the board communication failure.
you’ve to resolve USB port forwarding per VM environment.
if that’s possible,
please test on native Ubuntu OS desktop for image flashing
Hey, already did that. Forgot to mention about it! @JerryChang
did you meant you still cannot flash via native Ubuntu OS desktop?
No no, I instal native Ubuntu OS and flash the jetson on ssd disk,the system was flash properly except SDK components. Then I have configure CIS still camera is not detected. Or conected.
hello karlikha,
that’s likely what we doubt.. it’s a hardware damage.
Jetson it self or camera?
hello karlikha,
it should be your faulty camera hardware, please contact with sensor vendor for further supports.
Hey. I have checked camera on raspberry pi and it’s working perfectly.
as mentioned, we’ve check and confirm IMX219 is working on r36.4.3 + Jetson Orin Nano DevKit.
So what I should do give up? Buy new jetson?
hello karlikha,
please enable dual RPi camera v2 for testing.
besides, you may try to buy a new cable, that camera cable is fragile and easily broken.
if you believe that your Jetson product is defective, please contact the NVIDIA Customer Care team for the RMA (Return Material Authorization) process.
