Raspberry Pi Camera V2.1 with imx219 not working on Jetson Orin Nano Dev Kit
I am new to using a Jetson Orin Nano Dev Kit and I am getting an error when connecting a Raspberry pi v2.1 camera with imx219 sensor. I have set the IMX219 Dual Camera from jetson-io.py, but it still does not detect it. I don’t know what the problem could be.
I don’t think it’s a hardware problem because the camera was connected properly, and in the past I used it on a Raspberry Pi 4, and it worked there.
Looks like unable communicated with IMX219 via I2C command.
I guess it could be the cable problem.
I solved the problem. It was because of the incorrect cable connection. Thank you.
