I need help as I can’t seem to get the camera IMX219 to work by connecting the 15-22 ribbon cable pin converter to the CSI connecter.
The cable is Raspberry Pi Camera Cable
Jetson Orin Nano can’t even see the camera connected.
I tried checking if the board set up correctly, by running the command dmesg | grep imx219
I get an error that looks like this: bootdriver.log (522 Bytes)
Here is my set up:
Jetson Orin Nano DevKit
RPi ribbon cable 22-15 pin converter 200mm that is connected to CAM1 CSI connector
I also ran the command on overlay devicetree file: dtc -I dtb -O dts tegra234-p3737-overlay.dtbo
Which gave me a bunch of warnings: warnings_from_dtb.log (3.0 KB)
What caught my eye is the section with I2C_bus having warning with the address and reg
since I2C bus to my knowledge is responsible for CSI connecters:
<stdout>: Warning (i2c_bus_bridge): /fragment@0/__overlay__/i2c@c240000: incorrect #address-cells for I2C bus
<stdout>: Warning (i2c_bus_bridge): /fragment@0/__overlay__/i2c@c240000: incorrect #size-cells for I2C bus
<stdout>: Warning (i2c_bus_bridge): /fragment@1/__overlay__/i2c@c240000: incorrect #address-cells for I2C bus
<stdout>: Warning (i2c_bus_bridge): /fragment@1/__overlay__/i2c@c240000: incorrect #size-cells for I2C bus
<stdout>: Warning (i2c_bus_reg): Failed prerequisite 'i2c_bus_bridge'
If anyone understand what it means and how it causes the problem with camera not connecting I would appreciate it!
The log tell failed to communicate to IMX219 via i2c command.
That could be the cable connector problem. Try to reconnected or try connect to another port.
We have only 2 connectors in the Dev Kit, both of which give the same type of error no matter the amount of reconnects you try.
Do you think it could be a problem with driver or hardware?
I don’t think the problem can be related to cables as we tested with many different working cables.
If it comes to HW, do you think the problem is with Dev Kit or with Jetson Orin Nano.
Or do you think during the flashing of Jetson OS image the problem could be with The Host OS image?
Hey,
I tried reflashing the Jetson with different JetPacks 5.1.1, 5.1.2 and 5.1.3 and all of them give us the same error.
Maybe the flashing logs can help?
I tested the IMX219 on Raspberry Pi 4 and it worked fine so the problem can’t be related to the cameras,
just like we discussed it could either be a problem with HW or the drivers
Are you sure its not related to how i2c_bus is loaded or initiated?
Because this error happens regardless if the camera connected to CSI or not.
