Jetson nano B01 fails to detect rpi v2 camera ! Please find the dmesg log attached !
thanks!
Didn’t see the attached. Have you check the message first?
hello eyebies,
Raspberry Pi v2, IMX219 is by default supported.
please confirm you’re having correct pin connections. you may also have camera device connected before power-on the board,
thanks
Did you try turning off the Jetson, unplugging your csi camera, plugging it back in, and then turning the Jetson back on? I have had this issue before and this solved it.
TLDR: you can’t plug in the camera while the Jetson is on.
