Jetson Orin Nano module CAD position
I’m currently working on a project involving the Jetson Orin Nano 8GB module and a specific SODIMM connector. In the course of my work, I’ve encountered the need for information regarding the center position of the Jetson Orin Nano 8GB module in relation to the SODIMM connector for precise alignment.
The Jetson Orin Nano 8GB module details are as follows: 900-13767-0030-000, and the SODIMM connector information is: 2309407-1 (TE Connectivity). Despite my efforts to explore the available documentation for both the module and the SODIMM connector, I haven’t been able to locate specific details about the center position for proper alignment.
If anyone has worked on a similar integration or has information on determining the center position for alignment, I would greatly appreciate your advice. Are there specific documents, drawings, or guidelines that I may have overlooked?
Thank you for your time and assistance. I look forward to benefiting from your collective expertise.
Best regards.
This topic should be posted in the Jetson forums. I have moved it over for you
Hi, please refer to the module 3D CAD STEP model. Jetson Orin NX Series and Jetson Orin Nano Module 3D CAD STEP model
Thank you for your prompt response and valuable suggestions. I appreciate your insights.
I wanted to share an update on my progress. I already possess the 3D CAD STEP MODEL for both the Jetson Orin Nano 8GB module and the SODIMM connector. However, my challenge lies in determining the specific distances between the connector and the module, preventing me from creating the necessary footprint accurately.
To provide a visual aid, I’ve attached a figure illustrating the current positions. If there are any known or recommended distance goals between the Jetson Orin Nano 8GB module and the SODIMM connector, it would immensely help me refine the alignment and create a more precise footprint.
I’m keen on ensuring the optimal placement of the module, and any further insights or guidance on specific distance requirements would be incredibly beneficial
Maybe you can refer to below dimensions attached in the module data sheet.
Thank you for your response and providing the module dimensions. I’ve indeed utilized the available diagram to create the module symbol, as mentioned in the previous discussions.
However, my current challenge revolves around determining the optimal position of the SODIMM connector in relation to the Jetson Orin Nano 8GB module. As per our recent discussions, one potential alignment strategy could involve positioning the center of the connector at the extreme edge of the module card, as illustrated in the image from my last post.
I wanted to seek further insights from the community regarding this approach. Have any members had experience with similar configurations, or is there additional documentation or best practices that could shed light on the ideal alignment for the SODIMM connector?
I appreciate your continued support and look forward to any guidance the community may offer.
