Jetson orin nano not booting up and want to downgrade to jetpack 6.0 version
I have a Jetson Orin Nano that was working fine a few days ago with JetPack 6.2 and firmware version 36.3, but now it fails to boot completely. I have tried flashing JetPack 6.2 on both an SD card and a 512GB SSD, but the board still does not boot. When I power it on with an HDMI monitor connected, the screen remains black, and there are no signs of activity. I also tested without an SD card or SSD, but it still does not boot. I attempted to reflash the QSPI bootloader using SDK Manager, but the flashing process fails repeatedly. I also tried flashing manually using the flash.sh script, but it did not work.My other five Jetson Orin Nano boards work fine with the same setup, but this one has suddenly stopped functioning. I have tested different power adapters, USB-C cables, and ports, but nothing has helped. I need help diagnosing whether this is a software, QSPI corruption, or hardware failure issue.
Could you use sdk manager to full flash your device?
Please provide the flashing log and serial console log for us to review.
