Sorry to bother you.
I’m Asus IoT EE Leader, we currently have some issues regarding the Orin NX 16G SOM that we need your help to clarify.
Regarding the issue of sufficient wattage for 40W power.
We are using the Jetson Power GUI tool to monitor power, but after aging, both the CPU and GPU loading reach 100%, while the “VDD IN” is only 33W.
Is this correct? Is the SOM limiting the power to prevent the system from reaching the full 40W?
We try to modify the SOM’s instantaneous and average current limit, that power can up to 39W. May i ask if there are any concerns with modifying the current limit and has any impact items?
Additionally, do you have any recommended methods for the aging tool?
Are you verifying 40W power with the devkit or custom board for Orin NX 16G?
It may depend on your test tool.
How did you perform the test?
Do you modify the sysfs node manually?
If so, we don’t suggest doing that to prevent the damage to the SoM.
Please also take care of the cooling method to prevent high temperature when you are verifying with high power.
We’ve tried to run matrixMulCUBLAS from cuda-samples to perform stress test on the devkit and it could achieve 37W.
We’ve tried to run matrixMulCUBLAS (–sizemult=8) to perform stress test, the system only achieve 35W.
Our NV Kernel version is 36.4.3. May I ask that version you are testing?
Yes, we modify the sysfs nodes manually. So NV is don’t suggest we to modify it right?
Yes, we were also verifying Jetpack6.2(L4T r36.4.3) with super mode configuration.
Have you referred to Jetson/L4T/TRT Customized Example - eLinux.org and apply the patches there before the test?
Correct, the default limit is verified internally and we don’t suggest customer modifying them.
The intercepted log “Burnin_log” I provided here should be that the stress testing tool pulled up all CPU and GPU at once and caused the OC protection to be locked, which is why it is only about 33W.
