Jetson Orin NX is not booting
I faced the issue that my Jetson Orin NX stopped booting. While booting i see lines such as on the picture and after trying to run a job for /dev/ttyTCU0 for 1,5 minutes it just turn off the screen and nothing happen then.
I got some really important info on Jetson so i can’t just remove and reinstall OS from it.
Help me please.
I am also facing the same issue with seeed studio carrier board. Did you able to get a resolution for this issue?
Please help record the serial console log.
Also some questions to confirm:
  • Is your Orin NX using a dev kit or a carrier board?
Please reach out the seeed studio vendor to get the customized bsp.
Hi!
Already ordered usb-ttl cable. Will return with the logs.
My Orin NX using a dev kit
Wait for your log to do further check.
@DavidDDD Hi
In txt file i provide jetson’s logs while booting
log.txt (93.4 KB)
We notice you use older JP version.
Please try flash to latest JP version like 36.4.4 and cross check whether issue exists.
Hi!
Thanks for your reply.
Am I able to flash JP from SDK? And would this operation cause erasing data from Jetson?
~1008
