Jetson Orion nano drivers for SONY IMX 264
I am using the Jetson Orion Nano Dev Kit and trying to connect a Sony IMX264 sensor. However, I am unable to find a compatible driver for this sensor.
Could you please guide me on where I can find the driver or any relevant documentation to get this sensor working with the Jetson platform?
Please share vendor of the camera module. Would like to know if it’s from our camera partner.
If there’s no existing sensor driver and you would like to enable it, you can check
Sensor Software Driver Programming — NVIDIA Jetson Linux Developer Guide
Hi @durga.p,
Is the interface of your camera module MIPI-CSI2 or LVDS ?
Hi DaneLLL,
I have a sensor from Leopard Imaging, specifically the LI-IMX264-MIPI-M12. Here is the product link for reference:
Leopard Imaging IMX264 MIPI Camera
I would like to know if there are any existing drivers or device tree modifications required to get it working.
Has anyone successfully used this sensor with a Jetson board? Any guidance on integration and setup would be greatly appreciated.
Thanks in advance!
Hi Khang.I4es,
I am currently using MIPI-CSI2 interface.
Hi @durga.p,
I believe that Leopard Imaging should provide you at least the binary files of a certain Jetpack for the official Jetson Orin Nano Dev Kit. Otherwise, I can assist.
Hi @SimonZhu please help check this. Thanks.
@durga.p We don’t have Orin Nano driver for LI-IMX264-MIPI camera yet, but we can provide other Jetson drivers’ (e.g. AGX Orin) source code to you for reference if you would like to build the driver by yourselves.
Alternatively, we can provide custom driver services if needed.
Hi @SimonZhu ,
Could you kindly provide the AGX drivers along with the steps required to build them? Additionally, we would greatly appreciate any insights or guidance you can offer regarding custom driver services.
Here is the AGX Orin driver guide. The patch files (source code) can be downloaded from Dropbox in page1 for your reference if you would like to build your own drivers.
Regarding the custom driver service, please contact support@leopardimaging.com for more details.
