Hi, I encountered some issues while building the TensorRT-LLM package in my environment.
Is there a way to successfully build the TensorRT-LLM package for my system? Unfortunately, I cannot upgrade my Jetson to JetPack 6 due to hardware constraints. I attempted both manual building and using the
jetson-containers
builder, but both approaches failed similarly to the issue described here.I noticed the note in the
jetson-containers
github that mentions the compatibility of container images with other minor versions of JetPack/L4T:• L4T R32.7 containers can run on other versions of L4T R32.7 (JetPack 4.6+)
• L4T R35.x containers can run on other versions of L4T R35.x (JetPack 5.1+)
However, I couldn’t find specific support information for L4T R35.3.1 in the docs.
Could you provide any recommendations or guidance if it possible to build and how to proceed?
