Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Device '/dev/video0' has no supported format
New clock: GstSystemClock
Additional debug info:
../sys/v4l2/gstv4l2object.c(4399): gst_v4l2_object_set_format_full (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
Call to TRY_FMT failed for UYVY @ 1920x1080: Invalid argument
Execution ended after 0:00:00.000295455
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
Setting pipeline to NULL ...
../libs/gst/base/gstbasesrc.c(3177): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4)
Freeing pipeline ...
nvidia@tegra-ubuntu:~$ gst-launch-1.0 nvv4l2camerasrc device=/dev/video0 ! 'video/x-raw(memory:NVMM), format=(string)UYVY, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, interlace-mode=progressive' ! nvvidconv ! nv3dsink -e
ERROR: from element /GstPipeline:pipeline0/GstNv3dSink:nv3dsink0: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure.
../libs/gst/base/gstbasesink.c(5906): gst_base_sink_change_state (): /GstPipeline:pipeline0/GstNv3dSink:nv3dsink0:
Failed to start
ERROR: pipeline doesn't want to preroll.
Failed to set pipeline to PAUSED.
OK, roll back the mode_type and remove the use_sensor_mode_id and dynamic_pixel_bit_depth to try. If still unable to remove you may check trace the ../drivers/media/platform/tegra/camera/* to confirm the color formats report. Otherwise check the v4l2src code to figure out the error.
