Jetson Thor T5000 Module Pin Locations for AON GPIO Pins
In the Jetson Thor TRM on page 394 it mentions “In Thor, there are 32 AON GPIO Pins.” but nowhere does it list which pin locations on the module these would be located. I also reviewed the Pinmux Template Excel spreadsheet and I did not see them there either.
Can I get a list of the pin locations on the T5000 module for the AON GPIO pins?
Not all 32 AON pins map to the module connector. Many are already allocated for dedicated usage and not available. They are in rows 10-42 of the pinmux spreadsheet.
Thor CVM Connector Package Ball Name
Pin # Signal Name
L60 SYS_RESET_N SF_RST_N
B10 POWER_INT_N SF_PWR_INT_N
J60 MODULE_SLEEP_N SF_PWR_SOC_EN
J19 GPIO67 GP00
F61 VCOMP_ALERT_N GP01
B55 GPIO30/IST_DONE_N GP02
A61 SYSTEM_OC_N GP03
L61 POWER_BTN_N GP05
J50 HDMI_CEC GP06_HDMI_CEC
J61 I2C2_CLK GP10_I2C2_CLK
K61 I2C2_DAT GP11_I2C2_DAT
D61 I2C4_CLK GP12_I2C3_CLK
E60 I2C4_DAT GP13_I2C3_DAT
K62 FAN_PWM GP14_PWM4
H62 UART3_TX_DEBUG GP15_UART0_TX
K60 UART3_RX_DEBUG GP16_UART0_RX
E61 SPI2_CLK GP17_SPI2_CLK
D62 SPI2_MISO GP18_SPI2_MISO
F60 SPI2_MOSI GP19_SPI2_MOSI
D60 SPI2_CS0_N GP20_SPI2_CS0_N
B62 GPIO08 GP21
C61 GPIO09 GP22_SOCKET_ID_STRAP
E59 GPIO38 GP23_DDRCODE0
A39 GPIO37 GP24_DDRCODE1
A62 GPIO17 GP25_DDRCODE2
F59 GPIO42 GP26_DDRCODE3
L10 FORCE_RECOVERY_N GP27_RECOVERY0_STRAP
Thank you!
Upon further inspection, looking at the picture I attached up above, it shows on the right of the diagram that there are 8 GPIO’s going in/out of the AON GPIO Controller but in the caption below it says that there are 32 AON GPIO Pins? Does that imply that there are 4 AON GPIO Controllers? If that is the case, then which GPIO from the table you provided map to each?
Thank you.
When you select a pin to be a GPIO in the Pinmux Spreadsheet’s column AS, the controller port and pin number are shown. For example, GPIO13 is on controller port PQ pin 4 and GPIO40 is on the same port PQ pin 7. GPIO11 is on port PS pin 0.
