How do you configure the Jetson TK1 to use 2 lanes for Displayport instead of 4 lanes. Have displayport working for 4 lanes and tried to connect to a display that only uses two lanes. I get an error message DP:Channel Equalization failed. Resolution is 1920x1080 60Hz. tegra_dp_channel_eq( ) in source file dc/dp.c is called to check the equalization status and it loops for “n_lanes” which is set to a value of 2 and sets ce_done to false if either lane status (NV_DPCD_LANE0_1_STATUS) is not as expected. The first loop passes, the 2nd loop fails.
cioma
2
What display or panel do you use?
Related topics
| Display Port Interface Training Fails | 2 | 2628 | October 21, 2015 | |
| Jetson TX2 eDP 2 lane display question | 1 | 673 | October 24, 2017 | |
| Display Port on DP1, Display Port on DP0 | 3 | 761 | September 12, 2022 | |
| DP1.4 硬件配置2lane无法上4K分辨率 | 5 | 140 | May 19, 2026 | |
| DisplayPort (DP) interface displaying through 2 lanes | 7 | 730 | November 9, 2023 | |
| Display Port/Expansion on Jetson TK1 | 69 | 41714 | March 23, 2017 | |
| Display port enabled but not working | 2 | 1451 | August 18, 2020 | |
| How to configure edp's output? The number of lanes | 2 | 891 | July 31, 2018 | |
| How to cinfig display DP output lane number | 28 | 2265 | March 22, 2022 | |
| 2 lanes edp/ DP support? | 3 | 809 | July 21, 2023 |
