Jetson TK1 KVM or XEN?
I have few questions, does anyone has success running Xen or KVM on board?
I have opened below topic but didnt have answer yet. I was expecting at least I will see LPAE in CPU futures. Is that because of my kernel version (3.10) i see in Linus repo most of arm & xen support came after the version 3.11. Do you know l4t 19.3 have newer kernel?
https://devtalk.nvidia.com/default/topic/764781/embedded-systems/jetson-tk1-cortex-a15-virtualization-extensions/
In ubuntu trusty repo there is already KVM port but what I see in kvm-arm documentations most of cortex-A15 proof of concepts are done with a recompiled kernel for KVM. I believe U-boot support will be helpful to handle Xen. I will appreciate if anyone can guide me here to setup virtualization enviroment on right way.
I have not tried Xen or KVM.
The L4T R19.2 (shipping L4T) and R19.3 use version 3.10.24 as the base version kernel. There are some configuration differences, and firmware which are not part of the kernel.
Flashing to R19.3 gives you the option of u-boot (which I highly recommend), but you must specify this or else you get fastboot. Pretty much everything else is a kernel compile with your desired configuration (which is why I recomment u-boot…no need to flash a new kernel, just add zImage to /boot and edit the config to try it out). Kernel configure, compile, copy, edit extlinux.conf, and try it out. Make sure you have a serial console to catch the boot prompt with. Run command “boot” if you stop boot too soon (before kernel pick).
Thank you linuxdev I was hoping someone has already tried. Me and my friend is also trying to port kvm and xen. If I will have success I will just drop here some info but for any case feedbacks are welcome as I really need it:)
I also want to run kvm on jetson.
There is my idea.
  1. L4T R19.3 is basic on linux kernel 3.10.24 and kernel 3.10.24 have LPAE and kvm can be choiced in meneconfig. I can build a linux linux kernel include LPAE and KVM.
  2. Build a u-boot which can let cpu start at HYP mode.
If I complete above 2 things, can I see /dev/kvm?
I am also interested in running xen on the jetson Tk1. Did any of you try that? Any info would be appreciated.
I am porting KVM(Kernel-based Virtual Machine) on Tegra K1. Because there is some necessary address(the address where secondary cores jump to) which is board-dependent, I cannot port KVM. Could nVidia give me some help to let me get the address? (ref http://lists.denx.de/pipermail/u-boot/2013-May/153539.html )
I bought nVidia Tegra K1 and I’d like to run virtual machine on Tegra K1. According to my knowledge on ARM virtualization extension, if an user would like to boot VM with hardware virtualization support, Hyp mode should be opened. Because Hyp mode only can be opened when booting, I have to make sure that TK1’s U-boot do have switched on Hyp mode. Although TK1’s U-boot do have code pieces for switching on Hyp mode, but it’s not compilable. Because there are an critical board-dependent address (ref http://lists.denx.de/pipermail/u-boot/2013-May/153539.html ).
As a result, could nVidia help me to provide the address to let me port KVM on Tegra K1?
Some info here:
http://wiki.xenproject.org/wiki/Xen_ARMv7_with_Virtualization_Extensions
Just FYI, the URLs used as reference above show as “404…not found”. Is there another way to show which address information is required for your port?
EDIT: Put url tags around the quoted url’s so they should work without the ‘)’ getting in the way.
I guess the URLs work if you remove the ). from the end of them.
I’m sorry. Here is the correct website address.
NVIDIA doesn’t currently plan on supporting virtualization officially, but there is always a possibility that someone in the community could eventually support it such as by looking at upstream U-Boot + Linux kernel with the PSCI implementation, discussed at http://lists.denx.de/pipermail/u-boot/2015-April/thread.html#211516 in the entry:
[U-Boot] [PATCH v7 00/17] Add PSCI support for Jetson TK1/Tegra124 + CNTFRQ fix by Jan Kiszka
(and the 17 patches that follow it)
(It might be easier to download the patches from http://patchwork.ozlabs.org/project/uboot/list/?submitter=710, but once the patches are applied, that link won’t work anymore. Downloading the mbox file from http://lists.denx.de/pipermail/u-boot/ could work too.)
