Does anyone know the manufacturer and model # of the fan that comes mounted to the CPU Heat sink? I am trying to run some thermal/flow simulations but I need that info and I don’t physically have the kit so I can’t remove it and look.
Trumany
3
It is DCV-0917-N1-GP, you can check with vendor Coolermaster for more info.
Related topics
| DCV-01672-N2-GP Fan Specifications | 4 | 1953 | January 5, 2018 | |
| Heatsink for TX1 som | 1 | 981 | August 8, 2016 | |
| Tegra K1 Dev Board's CPU Fan | 9 | 2416 | March 23, 2017 | |
| Fan Heatsink CFM values | 3 | 352 | June 4, 2024 | |
| I am looking for the Thermal calculations for the Jetson TX1 development board | 1 | 561 | October 20, 2016 | |
| Cooling FAN part number for Jestson 4GB (900-83489-0080-000) Module | 1 | 489 | August 4, 2021 | |
| Jetson TX2 NX Heat Sink | 2 | 1933 | September 22, 2021 | |
| Heatsinks assembly with FAN | 1 | 153 | August 28, 2024 | |
| Fan for NVIDIA Jetson Xavier NX | 1 | 681 | August 17, 2020 | |
| Is the fan heatsink of Jetson Orin Nano the same as or compatible with the fan included in the Xavier NX devkit? | 1 | 735 | April 19, 2023 |
