I am trying to flush the target Jetson TX2 with JetPack 4.2 using SDK Manager and I get the following error:
10:44:50 INFO : Flash Jetson TX2 : exit status 1
10:44:50 INFO : Flash Jetson TX2 : [ Component Install Finished with Error ]
10:44:50 ERROR : Flash Jetson TX2 : NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP command sudo ./flash.sh jetson-tx2 mmcblk0p1 finished with error
10:44:50 INFO : Flash Jetson TX2 : [ 4.00 KB used. Disk Avail: 21.83 GB ]
10:44:50 INFO : Flash Jetson TX2 : [ NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP Install took 1m8s ]
10:44:50 INFO : Flash Jetson TX2 : command sudo ./flash.sh jetson-tx2 mmcblk0p1 finished with error
10:44:50 ERROR : Flash Jetson TX2 : command terminated with error
10:44:50 ERROR : Flash Jetson TX2 : install ‘Flash Jetson TX2’ failure, command < cd ‘/home/baz/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310’ ; /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a=‘install’ -c=‘eyJpZCI6Ik5WX0w0VF9GTEFTSF9UWDJfV0lUSF9PU19JTUFHRV9DT01QIiwibmFtZSI6IkZsYXNoIEpldHNvbiBUWDIiLCJkZXNjcmlwdGlvbiI6IkZsYXNoIEpldHNvbiBUWDIiLCJjb21wVHlwZSI6ImZsYXNoIiwiaXNWaXNpYmxlIjp0cnVlLCJsaWNlbnNlSWQiOiJOVl9KRVRQQUNLX09TX0VVTEEiLCJpc0RldGVjdGFibGVJbnN0YWxsIjpmYWxzZSwiaXNJbnN0YWxsUGF0aEN1c3RvbWl6YWJsZSI6dHJ1ZSwidGltZW91dFNlY29uZHMiOjM2MDAsInZlcnNpb24iOiIzMi4xIiwib3BlcmF0aW5nU3lzdGVtcyI6WyJ1YnVudHUxNjA0IiwidWJ1bnR1MTgwNCJdLCJpbnN0YWxsU2l6ZU1CIjozMDA1MywiZG93bmxvYWRGaWxlcyI6W10sImluc3RhbGxQYXJhbWV0ZXJzIjp7Imluc3RhbGxEaXIiOiJ7e1RBUkdFVF9ST09UfX0ve3tCVU5ETEVfVElUTEV9fV97e0JPQVJEX0lEfX0vTGludXhfZm9yX1RlZ3JhIiwiaW5zdGFsbENvbW1hbmRzIjpbeyJyZW1vdGVFeGVjQmFzaCI6WyJzdWRvIHJlYm9vdCBmb3JjZWQtcmVjb3ZlcnkiXSwiaWdub3JlRXJyb3IiOnRydWV9LHsiY29tbWVudCI6IndhaXQgZm9yIGRldmljZSB0byBzaHV0ZG93biBhbmQgdG8gZ28gdG8gcmVjb3ZlcnkgbW9kZSIsInVzZXJDb21tYW5kIjoic2xlZXAgMjAifSx7InVzZXJDb21tYW5kIjoic3VkbyAuL2ZsYXNoLnNoIGpldHNvbi10eDIgbW1jYmxrMHAxIn0seyJ1c2VyQ29tbWFuZCI6InNsZWVwIDEwIn1dfSwidGFyZ2V0SWRzIjpbIlAzMzEwIl0sImRlcGVuZGVuY2llcyI6W3siaWQiOiJOVl9MNFRfRklMRV9TWVNURU1fQU5EX09TX1RYMl9DT01QIiwib3BlcmF0b3IiOiI9PSIsInZlciI6IjMyLjEifSx7ImlkIjoiTlZfTDRUX0RSSVZFUlNfVFgyX0NPTVAiLCJvcGVyYXRvciI6Ij09IiwidmVyIjoiMzIuMSJ9LHsiaWQiOiJOVl9MNFRfREVWSUNFX01PREVfU0VUVVBfQ09NUF9JTl9GTEFTSCIsIm9wZXJhdG9yIjoiPT0iLCJ2ZXIiOiIxLjAifV0sImV4dGVybmFsX2RlcGVuZGVuY2llcyI6W10sInBhcmVudElEIjoiTlZfRFJJVkVfRkxBU0hfVEFSR0VUX0dST1VQIiwiYWN0aW9uIjoxLCJpbnN0YWxsUGF0aCI6Ii9ob21lL2Jhei9udmlkaWEvbnZpZGlhX3Nkay9KZXRQYWNrXzQuMl9MaW51eF9QMzMxMCIsImRvd25sb2FkRXJyb3JzIjpbXSwiYnVuZGxlVGl0bGUiOiJKZXRQYWNrXzQuMl9MaW51eCIsImluc3RhbGxSb290IjoiL2hvbWUvYmF6L252aWRpYS9udmlkaWFfc2RrIiwiYm9hcmRJRCI6IlAzMzEwIiwidGFyZ2V0QWNjZXNzSW5mbyI6eyJ1c2VyIjoibnZpZGlhIiwicGFzc3dvcmQiOiJudmRpYSIsImhvc3QiOiIxOTIuMTY4LjU1LjEiLCJwb3J0IjoiMjIifX0=’ -i=‘NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP’ -v=‘32.1’ -l=’/home/baz/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310’ -L=’/home/baz/.nvsdkm/logs/JetPack_4.2_Linux’ -p=‘1761’ -t=‘P3310’ -e=‘undefined’ > terminated with error
10:44:50 INFO : Device Mode Host Setup in Target SDK : install ‘Device Mode Host Setup in Target SDK’ Skipped
10:44:50 INFO : DateTime Target Setup : install ‘DateTime Target Setup’ Skipped
10:44:50 INFO : CUDA Toolkit for L4T : install ‘CUDA Toolkit for L4T’ Skipped
10:44:51 INFO : cuDNN on Target : install ‘cuDNN on Target’ Skipped
10:44:51 INFO : TensorRT on Target : install ‘TensorRT on Target’ Skipped
10:44:51 INFO : OpenCV on Target : install ‘OpenCV on Target’ Skipped
10:44:51 INFO : VisionWorks on Target : install ‘VisionWorks on Target’ Skipped
10:44:51 INFO : Multimedia API : install ‘Multimedia API’ Skipped
10:44:53 INFO : All done!
Please can you let me know, how I can over come this issue.
Many thanks
