Hi All,
docker runs normally without using gpu
But when I use option --runtime nvidia,error appeared.
Cannot be easily flash due to embedded board.
Is there a way to resolve the error without flash?
- Issue
docker: Error response from daemon: OCI runtime create failed: container_linux.go:380: starting container process caused: process_linux.go:545: container init caused: Running hook #0:: error running hook: exit status 1, stdout: , stderr: nvidia-container-cli: initialization error: driver error: failed to process request: unknown.
- Steps to reproduce the issue
docker run --runtime nvidia --network host -it nvcr.io/nvidia/l4t-base:r32.2.1
Information to attach (optional if deemed irrelevant)
sudo nvidia-container-cli -k -d /dev/tty info
-- WARNING, the following logs are for debugging purposes only -- I0907 08:05:09.483501 28389 nvc.c:372] initializing library context (version=1.5.0, build=4699c1b8b4991b6d869ea403e109291653bb040b) I0907 08:05:09.483604 28389 nvc.c:346] using root / I0907 08:05:09.483619 28389 nvc.c:347] using ldcache /etc/ld.so.cache I0907 08:05:09.483630 28389 nvc.c:348] using unprivileged user 65534:65534 I0907 08:05:09.483673 28389 nvc.c:389] attempting to load dxcore to see if we are running under Windows Subsystem for Linux (WSL) I0907 08:05:09.483865 28389 nvc.c:391] dxcore initialization failed, continuing assuming a non-WSL environment W0907 08:05:09.483985 28389 nvc.c:254] failed to detect NVIDIA devices I0907 08:05:09.484438 28390 nvc.c:274] loading kernel module nvidia E0907 08:05:09.485108 28390 nvc.c:276] could not load kernel module nvidia I0907 08:05:09.485168 28390 nvc.c:292] loading kernel module nvidia_uvm E0907 08:05:09.485433 28390 nvc.c:294] could not load kernel module nvidia_uvm I0907 08:05:09.485486 28390 nvc.c:301] loading kernel module nvidia_modeset E0907 08:05:09.485807 28390 nvc.c:303] could not load kernel module nvidia_modeset I0907 08:05:09.486481 28391 driver.c:101] starting driver service E0907 08:05:09.486915 28391 driver.c:168] could not start driver service: load library failed: libnvidia-ml.so.1: cannot open shared object file: no such file or directory I0907 08:05:09.487231 28389 driver.c:203] driver service terminated successfully nvidia-container-cli: initialization error: driver error: failed to process request -
cat /etc/nv_tegra_release
R32 (release), REVISION: 2.1, GCID: 16294929, BOARD: t186ref, EABI: aarch64, DATE: Tue Aug 13 04:45:36 UTC 2019 -
docker -v
Docker version 18.09.7, build 2d0083d -
dpkg -l ‘*nvidia*’
Desired=Unknown/Install/Remove/Purge/Hold | Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad) ||/ Name Version Architecture Description +++-==================================-======================-======================-========================================================================== un libgldispatch0-nvidia <none> <none> (no description available) ii libnvidia-container-tools 1.5.0-1 arm64 NVIDIA container runtime library (command-line tools) ii libnvidia-container0:arm64 0.9.0~beta.1 arm64 NVIDIA container runtime library ii libnvidia-container1:arm64 1.5.0-1 arm64 NVIDIA container runtime library un nvidia-304 <none> <none> (no description available) un nvidia-340 <none> <none> (no description available) un nvidia-384 <none> <none> (no description available) un nvidia-common <none> <none> (no description available) ii nvidia-container-runtime 3.5.0-1 arm64 NVIDIA container runtime un nvidia-container-runtime-hook <none> <none> (no description available) ii nvidia-container-toolkit 1.5.1-1 arm64 NVIDIA container runtime hook un nvidia-cuda-dev <none> <none> (no description available) un nvidia-libopencl1-dev <none> <none> (no description available) un nvidia-prime <none> <none> (no description available)
