Jetson TX2 USB cam problem
hi,
I use USB logitech 920,I found VideoCapture() is not work. opencv is OpenCV4Tegra.
import cv2
import sys
video_capture = cv2.VideoCapture(2) #USBcam is video 2,it’s right
print video_capture.isOpened()
result:False
please help!!
Hi ppdoll,
You may refer to below topic to see if any helps:
[url]https://devtalk.nvidia.com/default/topic/1027250/jetson-tx2/how-to-use-usb-webcam-in-jetson-tx2-with-python-and-opencv-/[/url]
Cheers
the result is always falut
It seems this is not an issue anymore, see
[url]How to use USB webcam in Jetson TX2 with Python and OpenCV? - Jetson TX2 - NVIDIA Developer Forums
Please share your full code here.
Also, please make sure /dev/video2 exists.
Does following command work for you? It should give out a preview on display.
$ gst-launch-1.0 v4l2src device="/dev/video2" ! "video/x-raw,width=640,height=480,format=I420" ! nvoverlaysink
