你好,我使用的设备是jetson orin nx,
在使用jetson-utils时,使用VideoOptions和VideoSource进行CSI相机的图像录制,可以达到19201080 60fps,但是当我使用这两个类进行将每一帧的图像进行逐帧保存时,他的帧率只有4fps左右,并且我看到他仅仅在cpu上运行,并没有像录制视频一样使用到gpu,请问我应该怎么修改才能达到像视频录制一样快的帧率,下面时采集图像的主要代码:
videoSource input = videoSource::Create(“csi://0”,options1);
videoOutput* output = videoOutput::Create(“file://…/resource/image_%i.jpg”,options1);
期待您的回复,感谢。
hello 1799545238,
may I know what’s the real use-case, would you like to capture every JPG file for the streaming?
for instance, 60 JPG images per second with your 1920x1080@60-fps camera sensor?
对的,我想以图像的形式把视频的每一帧保存下来,是否我应该使用jetson-utils搭配nvjpeg来实现此功能?
hello 1799545238,
let’s try with below gst pipeline for quick testing.
it’ll enable camera stream for saving 90 frames, (i.e. it should runs around 3-sec with a 30-fps camera sensor)
please update the resolution, fps…etc per your camera capability,
$ gst-launch-1.0 nvarguscamerasrc sensor-id=0 sensor-mode=0 num-buffers=90 ! 'video/x-raw(memory:NVMM),width=1920, height=1080, framerate=30/1, format=NV12' ! nvvidconv ! jpegenc ! multifilesink location=~/Desktop/tmp/capture%d.jpeg -e
很抱歉,我在运行您提供的代码时报错:ARGUS_ERROR: Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute: 1139 InvalidState.
GST_ARGUS: Cleaning up
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadExecute:694 NvBufSurfaceFromFd Failed.
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadFunction:247 (propagating)
错误:来自组件 /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0:CANCELLED
额外的调试信息:
Argus Error Status
允许关闭时发出 EOS 信号 —— 发生错误后等待EOS信号
等待 EOS 信号…
hello 1799545238,
may I know what’s the camera you’re working with? for exmaple, is it Bayer camera sensor or USB cameras?
抱歉,现在才回复你,我使用的是imx477 csi相机
hello 1799545238,
please execute $ dmesg | grep IMX477 to check you’ve sensor device register to linux kernel correctly.
you may also running v4l2 utility to check, $ v4l2-ctl -d /dev/video0 --list-formats-ext
是的,我可以读取,相机没有问题,我现在尝试使用nvjpg进行图像的编码,并且用到了multimedia中的编码图像的例子,但是我发现一张19201080的图像需要11毫秒左右,38402160的图像需要21ms左右,并且我看到jtop中的两块NVJPG和VIC使用在运行的,但是CPU的使用率也挺高的,有什么方法可以将编码的时间缩短吗
hello 1799545238,
it looks you’ve able to capture frames,
regrading to performance issues, please submit a new discussion thread to follow-up.
你好,我一直能够捕获帧,并且这个话题一开始就是在讨论性能问题,也许我的表达有误,让你误解了,我想要的是让图像帧能以60帧/秒的速度保存,请问我应该如何做到
It should be using software encoder in jetson-utils. For optimal solution, we suggest use jetson_multimedia_api to implement your use-case. Please check the samples in
/usr/src/jetson_multimedia_api/samples
For JPEG encoding, please check the sample
/usr/src/jetson_multimedia_api/samples/05_jpeg_encode
你好,我如何把multimedia中的例程引用到我的代码中,即我应该怎么在我的cmakelists中配置multimedia必要的库,我尝试了多次,但是一直编译失败,感谢你的帮助
Argus + hardware JPEG encoding is demonstrated in
/usr/src/jetson_multimedia_api/samples/09_argus_camera_jpeg/
You may run the sample with your camera and check if the JPEGs are saved.
