I am interested in the height of the module box and the height of the module from the PCB it is mounted onto (for both connector sizes).
The CAD model I have gives a height of 15.278mm,
The data sheet gives a different height of 16mm,
The data sheet also gives additional details which suggest a height of 1.57+9.5+4 = 15.07mm,
It also gives a dimension of 4mm from the under side of the unit to the PCB, is there a more accurate figure?
Thanks in advance,
