How to boot from sd card with jetson xavier nx?
I am using jetson xavier nx with A203 carrier board V2.
The initial setup has jetson linux R32.7.3 written to the eMMC.
I would like to write a jetpack 5.1.1 image to the sd card and boot from the sd card.
Currently, I have completed writing the jetpack 5.1.1 image to the sd card from my Mac using Etcher.
I have tried the following two things to see if I can boot from the sd card, but have not been able to do so.
- edit /boot/extlinux/extlinux.conf (boot configuration file) to boot from the image in the sdcard
1.1 Edit the default /boot/extlinux/extlinux.conf as follows (add LABEL for sdcard, set DEFAULT to sdcard, and root for sdcard to the sdcard partition (mmcblk1p1))
TIMEOUT 30
DEFAULT sdcard
MENU TITLE L4T boot options
LABEL primary
MENU LABEL primary kernel
LINUX /boot/Image
INITRD /boot/initrd
APPEND ${cbootargs} quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
LABEL sdcard
MENU LABEL sdcard kernel
LINUX /boot/Image
INITRD /boot/initrd
APPEND ${cbootargs} quiet root=/dev/mmcblk1p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
1.2 Restart
1.3 Log at boot time indicates that kernel module failed to load
- change the order of boot devices from UEFI
I tried to change the order of boot devices from the UEFI screen by referring to the following page, but the UEFI screen did not appear when I pressed the ESC key at boot time.
UEFI Adaptation — Jetson Linux Developer Guide documentation the-uefi-menu
Could you please tell me the correct procedure to boot jetson xavier nx from the sd card?
Thank you in advance.
