Jetson Xavier NX can not work after Reburning the system
Hello engineer, I have encountered an issue with the Xavier machine being unable to start when the image is burned to SSD. In the ubuntu system, after successfully burning, there is no output signal on the HDMI screen when the power is connected, and it is in a black screen state and cannot be turned on. May I ask what problem is causing this situation? In addition, I also attempted to burn the image onto an SD card, but unfortunately, the machine encountered the same problem.
This is my logs
*  Step 1: Build the flashing environment    *
Create flash environment 0
/media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/bootloader /media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra
Finish creating flash environment 0.
*  Step 2: Boot the device with flash initrd image *
/media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/temp_initrdflash/bootloader0 /media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra
./tegraflash.py --bl nvtboot_recovery_cpu_t194_sigheader.bin.encrypt --bct br_bct_BR.bct --securedev  --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --cmd "rcmboot"  --cfg secureflash.xml --chip 0x19 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt  --bins "mb2_bootloader nvtboot_recovery_t194_sigheader.bin.encrypt; mts_preboot preboot_c10_prod_cr_sigheader.bin.encrypt; mts_mce mce_c10_prod_cr_sigheader.bin.encrypt; mts_proper mts_c10_prod_cr_sigheader.bin.encrypt; bpmp_fw bpmp_t194_sigheader.bin.encrypt; bpmp_fw_dtb tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt; spe_fw spe_t194_sigheader.bin.encrypt; tlk tos-trusty_t194_sigheader.img.encrypt; eks eks_sigheader.img.encrypt; kernel boot0.img; kernel_dtb kernel_tegra194-p3668-all-p3509-0000.dtb; bootloader_dtb tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt"    --instance 3-2
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
 Entering RCM boot
[   0.0000 ] rcm boot with presigned binaries
[   0.0000 ] Boot Rom communication
[   0.0022 ] tegrarcm_v2 --instance 3-2 --chip 0x19 0 --rcm rcm_1_encrypt.rcm --rcm rcm_2_encrypt.rcm
[   0.0027 ] BR_CID: 0x88021911647d15030c000000170282c0
[   0.0092 ] Boot Rom communication completed
[   1.0300 ]
[   2.0334 ] tegrarcm_v2 --instance 3-2 --isapplet
[   2.0341 ] Applet version 01.00.0000
[   2.0472 ]
[   2.0472 ] Sending BCTs
[   2.0494 ] tegrarcm_v2 --instance 3-2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
[   2.0500 ] Applet version 01.00.0000
[   2.0624 ] Sending bct_bootrom
[   2.0624 ] [................................................] 100%
[   2.0644 ] Sending bct_mb1
[   2.0700 ] [................................................] 100%
[   2.0745 ] Sending bct_mem
[   2.1250 ] [................................................] 100%
[   2.2006 ]
[   2.2006 ] Generating blob
[   2.2030 ] tegrahost_v2 --chip 0x19 --generateblob blob.xml blob.bin
[   2.2036 ] number of images in blob are 13
[   2.2038 ] blobsize is 60921976
[   2.2038 ] Added binary blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt of size 263840
[   2.3828 ] Added binary blob_nvtboot_recovery_t194_sigheader.bin.encrypt of size 181152
[   2.3830 ] Added binary blob_preboot_c10_prod_cr_sigheader.bin.encrypt of size 24016
[   2.3831 ] Added binary blob_mce_c10_prod_cr_sigheader.bin.encrypt of size 143200
[   2.3833 ] Added binary blob_mts_c10_prod_cr_sigheader.bin.encrypt of size 3430416
[   2.3944 ] Added binary blob_bpmp_t194_sigheader.bin.encrypt of size 856352
[   2.3952 ] Added binary blob_tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt of size 281984
[   2.3955 ] Added binary blob_spe_t194_sigheader.bin.encrypt of size 94960
[   2.3956 ] Added binary blob_tos-trusty_t194_sigheader.img.encrypt of size 410560
[   2.3957 ] Added binary blob_eks_sigheader.img.encrypt of size 5136
[   2.3958 ] Added binary blob_boot0.img of size 54816768
[   2.5784 ] Added binary blob_kernel_tegra194-p3668-all-p3509-0000.dtb of size 204640
[   2.5878 ] Added binary blob_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt of size 208736
[   2.6530 ]
[   2.6530 ] Sending bootloader and pre-requisite binaries
[   2.6555 ] tegrarcm_v2 --instance 3-2 --download blob blob.bin
[   2.6560 ] Applet version 01.00.0000
[   2.6679 ] Sending blob
[   2.6679 ] [                                                ] 001%
[   2.6679 ] [.                                               ] 003%
[   2.6679 ] [..                                              ] 005%
[   2.6679 ] [...                                             ] 006%
[   2.6679 ] [....                                            ] 008%
[   2.6679 ] [.....                                           ] 010%
[   2.6679 ] [......                                          ] 012%
[   2.6679 ] [......                                          ] 013%
[   2.6679 ] [.......                                         ] 015%
[   2.6679 ] [........                                        ] 017%
[   2.6679 ] [.........                                       ] 018%
[   2.6679 ] [..........                                      ] 020%
[   2.6679 ] [...........                                     ] 022%
[   2.6679 ] [............                                    ] 024%
[   2.6679 ] [............                                    ] 025%
[   2.6679 ] [.............                                   ] 027%
[   2.6679 ] [..............                                  ] 029%
[   2.6679 ] [...............                                 ] 030%
[   2.6679 ] [................                                ] 032%
[   2.6679 ] [.................                               ] 034%
[   2.6679 ] [..................                              ] 036%
[   2.6679 ] [..................                              ] 037%
[   2.6679 ] [...................                             ] 039%
[   2.6679 ] [....................                            ] 041%
[   2.6679 ] [.....................                           ] 043%
[   2.6679 ] [......................                          ] 044%
[   2.6679 ] [.......................                         ] 046%
[   2.6679 ] [........................                        ] 048%
[   2.6679 ] [........................                        ] 049%
[   2.6679 ] [.........................                       ] 051%
[   2.6679 ] [..........................                      ] 053%
[   2.6679 ] [...........................                     ] 055%
[   2.6679 ] [............................                    ] 056%
[   2.6679 ] [.............................                   ] 058%
[   2.6679 ] [..............................                  ] 060%
[   2.6679 ] [..............................                  ] 061%
[   2.6679 ] [...............................                 ] 063%
[   2.6679 ] [................................                ] 065%
[   2.6679 ] [.................................               ] 067%
[   2.6679 ] [..................................              ] 068%
[   2.6679 ] [...................................             ] 070%
[   2.6679 ] [....................................            ] 072%
[   2.6679 ] [.....................................           ] 074%
[   2.6679 ] [.....................................           ] 075%
[   2.6679 ] [......................................          ] 077%
[   2.6679 ] [.......................................         ] 079%
[   2.6679 ] [........................................        ] 080%
[   2.6679 ] [.........................................       ] 082%
[   2.6679 ] [..........................................      ] 084%
[   2.6679 ] [...........................................     ] 086%
[   2.6679 ] [...........................................     ] 087%
[   2.6679 ] [............................................    ] 089%
[   2.6679 ] [.............................................   ] 091%
[   2.6679 ] [..............................................  ] 092%
[   2.6679 ] [............................................... ] 094%
[   2.6679 ] [................................................] 096%
[   2.6679 ] [................................................] 098%
[   2.6679 ] [................................................] 099%
[   2.6679 ] [................................................] 100%
[  11.0659 ]
[  11.0682 ] tegrarcm_v2 --instance 3-2 --boot rcm
[  11.0688 ] Applet version 01.00.0000
[  11.0856 ]
[  11.0856 ] RCM-boot started
*  Step 3: Start the flashing process *
Waiting for target to boot-up...
Waiting for device to expose ssh ......Run command: if [ -f /qspi/l4t_flash_from_kernel.sh ]; then USER=root /qspi/l4t_flash_from_kernel.sh --no-reboot --qspi-only ; fi on root@fe80::1%ens160u2
blockdev: cannot open /dev/sdc: No medium found
[ 0]: l4t_flash_from_kernel: Starting to create gpt for emmc
Active index file is /media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/internal/flash.idx
Number of lines is 62
max_index=61
blockdev: cannot open /dev/mmcblk0boot0: No such file or directory
Flash index file is /qspi/internal/flash.idx
max_index=61
[ 0]: l4t_flash_from_kernel: Starting to flash to qspi
Erasing 64 Kibyte @ 0 --  0 % complete writing item=49, 1:3:primary_gpt, 512, 19968, gpt_primary_1_3.bin, 16896, fixed-<reserved>-0, 64aca26042e345e8f544ee9fce940bc8e2ebd247
Writing primary_gpt partition with gpt_primary_1_3.bin
Offset is not aligned to K Bytes, no optimization is applied
dd if=/media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/internal/gpt_primary_1_3.bin of=/dev/sdb bs=1 skip=0  seek=512 count=16896
16896+0 records in
16896+0 records out
16896 bytes (17 kB, 16 KiB) copied, 0.0102468 s, 1.6 MB/s
Writing primary_gpt partition done
Error: The backup GPT table is corrupt, but the primary appears OK, so that will be used.
Warning: Not all of the space available to /dev/sdb appears to be used, you can fix the GPT to use all of the space (an extra 93892607 blocks) or continue with the current setting?
Writing secondary_gpt partition with gpt_secondary_1_3.bin
dd if=/media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/internal/gpt_secondary_1_3.bin of=/dev/sdb bs=1 skip=0  seek=15757983232 count=16896
16896+0 records in
16896+0 records out
16896 bytes (17 kB, 16 KiB) copied, 0.0459649 s, 368 kB/s
Writing secondary_gpt partition done
Error: The backup GPT table is not at the end of the disk, as it should be.  Fix, by moving the backup to the end (and removing the old backup)?
Fix/Ignore? Fix
Fix/Ignore? Fix
Model: mmc0 0 (scsi)
Disk /dev/sdb: 63.8GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number  Start   End     Size    File system  Name               Flags
 1      20.5kB  15.0GB  15.0GB  fat32        APP                msftdata
 2      15.0GB  15.1GB  67.1MB  fat16        kernel             msftdata
 3      15.1GB  15.2GB  67.1MB  fat16        kernel_b           msftdata
 4      15.2GB  15.2GB  459kB                kernel-dtb         msftdata
 5      15.2GB  15.2GB  459kB                kernel-dtb_b       msftdata
 6      15.2GB  15.2GB  66.1MB  fat16        recovery           msftdata
 7      15.2GB  15.2GB  524kB                recovery-dtb       msftdata
 8      15.2GB  15.2GB  262kB                kernel-bootctrl    msftdata
 9      15.2GB  15.2GB  262kB                kernel-bootctrl_b  msftdata
10      15.2GB  15.5GB  315MB   fat16        RECROOTFS          msftdata
11      15.5GB  15.8GB  209MB                UDA                msftdata
[ 2]: l4t_flash_from_kernel: Expanding last partition to fill the storage device
Erasing 64 Kibyte @ 10000 --  0 % complete
Erasing 64 Kibyte @ 20000 --  0 % complete
Erasing 64 Kibyte @ 30000 --  0 % complete [ 3]: l4t_flash_from_kernel: Successfully create gpt for emmc
[ 3]: l4t_flash_from_kernel: Starting to create gpt for external device
Active index file is /media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/external/flash.idx
Number of lines is 14
max_index=13
writing item=1, 9:0:primary_gpt, 512, 19968, gpt_primary_9_0.bin, 16896, fixed-<reserved>-0, 8c70e8425c976a2e8dbf798080d9d7fcc8fb1a71
Erasing 64 Kibyte @ 40000 --  0 % complete
Erasing 64 Kibyte @ 50000 --  0 % complete Writing primary_gpt partition with gpt_primary_9_0.bin
dd if=/media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/external/gpt_primary_9_0.bin of=/dev/sde bs=1 skip=0  seek=512 count=16896
16896+0 records in
16896+0 records out
16896 bytes (17 kB, 16 KiB) copied, 0.0095531 s, 1.8 MB/s
Erasing 64 Kibyte @ 60000 --  1 % complete
Erasing 64 Kibyte @ 70000 --  1 % complete
Erasing 64 Kibyte @ 80000 --  1 % complete Writing secondary_gpt partition with gpt_secondary_9_0.bin
dd if=/media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/external/gpt_secondary_9_0.bin of=/dev/sde bs=1 skip=0  seek=512110173696 count=16896
16896+0 records in
16896+0 records out
16896 bytes (17 kB, 16 KiB) copied, 0.0315343 s, 536 kB/s
[ 4]: l4t_flash_from_kernel: Successfully create gpt for external device
Run command: partprobe on root@fe80::1%ens160u2
Erasing 64 Kibyte @ 90000 --  1 % complete
Erasing 64 Kibyte @ a0000 --  1 % complete
Erasing 64 Kibyte @ b0000 --  2 % complete
Erasing 64 Kibyte @ c0000 --  2 % complete
Erasing 64 Kibyte @ d0000 --  2 % complete
Erasing 64 Kibyte @ e0000 --  2 % complete
Erasing 64 Kibyte @ f0000 --  2 % complete
Erasing 64 Kibyte @ 100000 --  3 % complete
Erasing 64 Kibyte @ 110000 --  3 % complete [ 7]: l4t_flash_from_kernel: Starting to flash to emmc
[ 7]: l4t_flash_from_kernel: Starting to flash to external device
max_index=13
max_index=61
writing item=0, 9:0:master_boot_record, 0, 512, mbr_9_0.bin, 512, fixed-<reserved>-0, 694898d1c345bdb31b377790ed7fc0b0db184bf7
writing item=2, 9:0:APP, 20480, 510027366400, , , fixed-<reserved>-1,
Erasing 64 Kibyte @ 120000 --  3 % complete writing item=48, 1:3:master_boot_record, 0, 512, mbr_1_3.bin, 512, fixed-<reserved>-0, 694898d1c345bdb31b377790ed7fc0b0db184bf7
writing item=50, 1:3:APP, 20480, 15032385536, , , fixed-<reserved>-1,
Formatting APP partition /dev/sde1 ...
mke2fs 1.44.1 (24-Mar-2018)
Creating filesystem with 124518400 4k blocks and 31129600 inodes
Filesystem UUID: 548e99e7-b68d-43b2-aefd-218288201752
Superblock backups stored on blocks:
	32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
	4096000, 7962624, 11239424, 20480000, 23887872, 71663616, 78675968,
	102400000
Allocating group tables:    0/3800         done
Writing inode tables:    0/3800         done
Creating journal (262144 blocks): Formatting APP partition /dev/sdb1 ...
Creating filesystem with 3670016 4k blocks and 917504 inodes
Filesystem UUID: 8608decc-ea98-42e2-8159-aa8c2960763c
Allocating group tables:   0/112       done
Writing inode tables:   0/112       done
Creating journal (16384 blocks):
Erasing 64 Kibyte @ 130000 --  3 % complete done
Writing superblocks and filesystem accounting information:   0/112
Erasing 64 Kibyte @ 140000 --  3 % complete
Erasing 64 Kibyte @ 150000 --  4 % complete
Erasing 64 Kibyte @ 160000 --  4 % complete
Erasing 64 Kibyte @ 170000 --  4 % complete
Erasing 64 Kibyte @ 180000 --  4 % complete
Erasing 64 Kibyte @ 190000 --  4 % complete
Erasing 64 Kibyte @ 1a0000 --  5 % complete
Erasing 64 Kibyte @ 1b0000 --  5 % complete
Erasing 64 Kibyte @ 1c0000 --  5 % complete
Erasing 64 Kibyte @ 1d0000 --  5 % complete
Erasing 64 Kibyte @ 1e0000 --  5 % complete
Erasing 64 Kibyte @ 1f0000 --  6 % complete
Erasing 64 Kibyte @ 200000 --  6 % complete
Erasing 64 Kibyte @ 210000 --  6 % complete done
Formatting APP parition done
Erasing 64 Kibyte @ 220000 --  6 % complete done
Writing superblocks and filesystem accounting information:    0/3800Formatting APP partition /dev/sdb1 ...
tar --xattrs -xpf /media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/internal/system.img  --checkpoint=10000 --warning=no-timestamp --numeric-owner  -C  /tmp/ci-gbUN4Tz0h6
Erasing 64 Kibyte @ 230000 --  6 % complete    2/3800
Erasing 64 Kibyte @ 240000 --  7 % complete
Erasing 64 Kibyte @ 250000 --  7 % complete
Erasing 64 Kibyte @ 260000 --  7 % complete
Erasing 64 Kibyte @ 270000 --  7 % complete    6/3800
Erasing 64 Kibyte @ 280000 --  7 % complete
Erasing 64 Kibyte @ 290000 --  8 % complete
Erasing 64 Kibyte @ 2a0000 --  8 % complete
Erasing 64 Kibyte @ 2b0000 --  8 % complete
Erasing 64 Kibyte @ 2c0000 --  8 % complete
Erasing 64 Kibyte @ 2d0000 --  8 % complete
Erasing 64 Kibyte @ 2e0000 --  8 % complete
Erasing 64 Kibyte @ 2f0000 --  9 % complete
Erasing 64 Kibyte @ 300000 --  9 % complete
Erasing 64 Kibyte @ 310000 --  9 % complete
Erasing 64 Kibyte @ 320000 --  9 % complete
Erasing 64 Kibyte @ 330000 --  9 % complete
Erasing 64 Kibyte @ 340000 -- 10 % complete
Erasing 64 Kibyte @ 350000 -- 10 % complete
Erasing 64 Kibyte @ 360000 -- 10 % complete
Erasing 64 Kibyte @ 370000 -- 10 % complete
Erasing 64 Kibyte @ 380000 -- 10 % complete
Erasing 64 Kibyte @ 390000 -- 11 % complete
Erasing 64 Kibyte @ 3a0000 -- 11 % complete
Erasing 64 Kibyte @ 3b0000 -- 11 % complete
Erasing 64 Kibyte @ 3c0000 -- 11 % complete
Erasing 64 Kibyte @ 3d0000 -- 11 % complete
Erasing 64 Kibyte @ 3e0000 -- 12 % complete
Erasing 64 Kibyte @ 3f0000 -- 12 % complete
Erasing 64 Kibyte @ 400000 -- 12 % complete
Erasing 64 Kibyte @ 410000 -- 12 % complete
Erasing 64 Kibyte @ 420000 -- 12 % complete
Erasing 64 Kibyte @ 430000 -- 13 % complete
Erasing 64 Kibyte @ 440000 -- 13 % complete
Erasing 64 Kibyte @ 450000 -- 13 % complete
Erasing 64 Kibyte @ 460000 -- 13 % complete
Erasing 64 Kibyte @ 470000 -- 13 % complete
Erasing 64 Kibyte @ 480000 -- 14 % complete
Erasing 64 Kibyte @ 490000 -- 14 % complete
Erasing 64 Kibyte @ 4a0000 -- 14 % complete
Erasing 64 Kibyte @ 4b0000 -- 14 % complete
Erasing 64 Kibyte @ 4c0000 -- 14 % complete
Erasing 64 Kibyte @ 4d0000 -- 15 % complete
Erasing 64 Kibyte @ 4e0000 -- 15 % complete
Erasing 64 Kibyte @ 4f0000 -- 15 % complete
Erasing 64 Kibyte @ 500000 -- 15 % complete
Erasing 64 Kibyte @ 510000 -- 15 % complete
Erasing 64 Kibyte @ 520000 -- 16 % complete
Erasing 64 Kibyte @ 530000 -- 16 % complete
Erasing 64 Kibyte @ 540000 -- 16 % complete
Erasing 64 Kibyte @ 550000 -- 16 % complete
Erasing 64 Kibyte @ 560000 -- 16 % complete
Erasing 64 Kibyte @ 570000 -- 16 % complete
Erasing 64 Kibyte @ 580000 -- 17 % complete
Erasing 64 Kibyte @ 590000 -- 17 % complete
Erasing 64 Kibyte @ 5a0000 -- 17 % complete
Erasing 64 Kibyte @ 5b0000 -- 17 % complete
Erasing 64 Kibyte @ 5c0000 -- 17 % complete
Erasing 64 Kibyte @ 5d0000 -- 18 % complete
Erasing 64 Kibyte @ 5e0000 -- 18 % complete
Erasing 64 Kibyte @ 5f0000 -- 18 % complete
Erasing 64 Kibyte @ 600000 -- 18 % complete
Erasing 64 Kibyte @ 610000 -- 18 % complete
Erasing 64 Kibyte @ 620000 -- 19 % complete
Erasing 64 Kibyte @ 630000 -- 19 % complete
Erasing 64 Kibyte @ 640000 -- 19 % complete
Erasing 64 Kibyte @ 650000 -- 19 % complete
Erasing 64 Kibyte @ 660000 -- 19 % complete
Erasing 64 Kibyte @ 670000 -- 20 % complete
Erasing 64 Kibyte @ 680000 -- 20 % complete
Erasing 64 Kibyte @ 690000 -- 20 % complete
Erasing 64 Kibyte @ 6a0000 -- 20 % complete
Erasing 64 Kibyte @ 6b0000 -- 20 % complete
Erasing 64 Kibyte @ 6c0000 -- 21 % complete
Erasing 64 Kibyte @ 6d0000 -- 21 % complete
Erasing 64 Kibyte @ 6e0000 -- 21 % complete
Erasing 64 Kibyte @ 6f0000 -- 21 % complete
Erasing 64 Kibyte @ 700000 -- 21 % complete
Erasing 64 Kibyte @ 710000 -- 22 % complete
Erasing 64 Kibyte @ 720000 -- 22 % complete
Erasing 64 Kibyte @ 730000 -- 22 % complete
Erasing 64 Kibyte @ 740000 -- 22 % complete
Erasing 64 Kibyte @ 750000 -- 22 % complete
Erasing 64 Kibyte @ 760000 -- 23 % complete
Erasing 64 Kibyte @ 770000 -- 23 % complete
Erasing 64 Kibyte @ 780000 -- 23 % complete
Erasing 64 Kibyte @ 790000 -- 23 % complete
Erasing 64 Kibyte @ 7a0000 -- 23 % complete
Erasing 64 Kibyte @ 7b0000 -- 24 % complete
Erasing 64 Kibyte @ 7c0000 -- 24 % complete
Erasing 64 Kibyte @ 7d0000 -- 24 % complete
Erasing 64 Kibyte @ 7e0000 -- 24 % complete
Erasing 64 Kibyte @ 7f0000 -- 24 % complete
Erasing 64 Kibyte @ 800000 -- 25 % complete
Erasing 64 Kibyte @ 810000 -- 25 % complete
Erasing 64 Kibyte @ 820000 -- 25 % complete
Erasing 64 Kibyte @ 830000 -- 25 % complete
Erasing 64 Kibyte @ 840000 -- 25 % complete
Erasing 64 Kibyte @ 850000 -- 25 % complete
Erasing 64 Kibyte @ 860000 -- 26 % complete
Erasing 64 Kibyte @ 870000 -- 26 % complete
Erasing 64 Kibyte @ 880000 -- 26 % complete
Erasing 64 Kibyte @ 890000 -- 26 % complete
Erasing 64 Kibyte @ 8a0000 -- 26 % complete
Erasing 64 Kibyte @ 8b0000 -- 27 % complete
Erasing 64 Kibyte @ 8c0000 -- 27 % complete
Erasing 64 Kibyte @ 8d0000 -- 27 % complete
Erasing 64 Kibyte @ 8e0000 -- 27 % complete
Erasing 64 Kibyte @ 8f0000 -- 27 % complete
Erasing 64 Kibyte @ 900000 -- 28 % complete
Erasing 64 Kibyte @ 910000 -- 28 % complete
Erasing 64 Kibyte @ 920000 -- 28 % complete
Erasing 64 Kibyte @ 930000 -- 28 % complete
Erasing 64 Kibyte @ 940000 -- 28 % complete
Erasing 64 Kibyte @ 950000 -- 29 % complete
Erasing 64 Kibyte @ 960000 -- 29 % complete
Erasing 64 Kibyte @ 970000 -- 29 % complete
Erasing 64 Kibyte @ 980000 -- 29 % complete
Erasing 64 Kibyte @ 990000 -- 29 % complete
Erasing 64 Kibyte @ 9a0000 -- 30 % complete
Erasing 64 Kibyte @ 9b0000 -- 30 % complete
Erasing 64 Kibyte @ 9c0000 -- 30 % complete
Erasing 64 Kibyte @ 9d0000 -- 30 % complete
Erasing 64 Kibyte @ 9e0000 -- 30 % complete
Erasing 64 Kibyte @ 9f0000 -- 31 % complete
Erasing 64 Kibyte @ a00000 -- 31 % complete
Erasing 64 Kibyte @ a10000 -- 31 % complete
Erasing 64 Kibyte @ a20000 -- 31 % complete
Erasing 64 Kibyte @ a30000 -- 31 % complete
Erasing 64 Kibyte @ a40000 -- 32 % complete writing item=51, 1:3:kernel, 15032406016, 67108864, boot_sigheader.img.encrypt, 41732096, fixed-<reserved>-2, d260e548457f90b096ba8057d4059a36e19eee6b
Writing kernel partition with boot_sigheader.img.encrypt
Get size of partition through connection.
done
41732096 bytes from /media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/internal/boot_sigheader.img.encrypt to /dev/sdb: 1KB block=40754 remainder=0
dd if=/media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/internal/boot_sigheader.img.encrypt of=/dev/sdb bs=1K skip=0  seek=14680084 count=40754
tar --xattrs -xpf /media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/external/system.img  --checkpoint=10000 --warning=no-timestamp --numeric-owner  -C  /tmp/ci-7Gj6mkWhzP
Erasing 64 Kibyte @ a50000 -- 32 % complete
Erasing 64 Kibyte @ a60000 -- 32 % complete
Erasing 64 Kibyte @ a70000 -- 32 % complete tar: Read checkpoint 10000
Erasing 64 Kibyte @ a80000 -- 32 % complete
Erasing 64 Kibyte @ a90000 -- 33 % complete
Erasing 64 Kibyte @ aa0000 -- 33 % complete
Erasing 64 Kibyte @ ab0000 -- 33 % complete
Erasing 64 Kibyte @ ac0000 -- 33 % complete tar: Read checkpoint 20000
Erasing 64 Kibyte @ ad0000 -- 33 % complete
Erasing 64 Kibyte @ ae0000 -- 33 % complete
Erasing 64 Kibyte @ af0000 -- 34 % complete
Erasing 64 Kibyte @ b00000 -- 34 % complete
Erasing 64 Kibyte @ b10000 -- 34 % complete tar: Read checkpoint 30000
Erasing 64 Kibyte @ b20000 -- 34 % complete
Erasing 64 Kibyte @ b30000 -- 34 % complete
Erasing 64 Kibyte @ b40000 -- 35 % complete
Erasing 64 Kibyte @ b50000 -- 35 % complete tar: Read checkpoint 40000
Erasing 64 Kibyte @ b60000 -- 35 % complete
Erasing 64 Kibyte @ b70000 -- 35 % complete
Erasing 64 Kibyte @ b80000 -- 35 % complete
Erasing 64 Kibyte @ b90000 -- 36 % complete tar: Read checkpoint 50000
Erasing 64 Kibyte @ ba0000 -- 36 % complete
Erasing 64 Kibyte @ bb0000 -- 36 % complete
Erasing 64 Kibyte @ bc0000 -- 36 % complete tar: Read checkpoint 60000
Erasing 64 Kibyte @ bd0000 -- 36 % complete 40754+0 records in
40754+0 records out
41732096 bytes (42 MB, 40 MiB) copied, 6.66305 s, 6.3 MB/s
Erasing 64 Kibyte @ be0000 -- 37 % complete
Erasing 64 Kibyte @ bf0000 -- 37 % complete tar: Read checkpoint 70000
Erasing 64 Kibyte @ c00000 -- 37 % complete
Erasing 64 Kibyte @ c10000 -- 37 % complete
Erasing 64 Kibyte @ c20000 -- 37 % complete
Erasing 64 Kibyte @ c30000 -- 38 % complete tar: Read checkpoint 80000
Erasing 64 Kibyte @ c40000 -- 38 % complete
Erasing 64 Kibyte @ c50000 -- 38 % complete tar: Read checkpoint 90000
Erasing 64 Kibyte @ c60000 -- 38 % complete
Erasing 64 Kibyte @ c70000 -- 38 % complete tar: Read checkpoint 100000
Erasing 64 Kibyte @ c80000 -- 39 % complete
Erasing 64 Kibyte @ c90000 -- 39 % complete tar: Read checkpoint 110000
Erasing 64 Kibyte @ ca0000 -- 39 % complete
Erasing 64 Kibyte @ cb0000 -- 39 % complete
Erasing 64 Kibyte @ cc0000 -- 39 % complete tar: Read checkpoint 120000
Erasing 64 Kibyte @ cd0000 -- 40 % complete
Erasing 64 Kibyte @ ce0000 -- 40 % complete
Erasing 64 Kibyte @ cf0000 -- 40 % complete
Erasing 64 Kibyte @ d00000 -- 40 % complete
Erasing 64 Kibyte @ d10000 -- 40 % complete tar: Read checkpoint 130000
Erasing 64 Kibyte @ d20000 -- 41 % complete
Erasing 64 Kibyte @ d30000 -- 41 % complete
Erasing 64 Kibyte @ d40000 -- 41 % complete
Erasing 64 Kibyte @ d50000 -- 41 % complete
Erasing 64 Kibyte @ d60000 -- 41 % complete
Erasing 64 Kibyte @ d70000 -- 41 % complete tar: Read checkpoint 140000
Erasing 64 Kibyte @ d80000 -- 42 % complete
Erasing 64 Kibyte @ d90000 -- 42 % complete
Erasing 64 Kibyte @ da0000 -- 42 % complete
Erasing 64 Kibyte @ db0000 -- 42 % complete
Erasing 64 Kibyte @ dc0000 -- 42 % complete
Erasing 64 Kibyte @ dd0000 -- 43 % complete tar: Read checkpoint 150000
Erasing 64 Kibyte @ de0000 -- 43 % complete
Erasing 64 Kibyte @ df0000 -- 43 % complete
Erasing 64 Kibyte @ e00000 -- 43 % complete
Erasing 64 Kibyte @ e10000 -- 43 % complete
Erasing 64 Kibyte @ e20000 -- 44 % complete
Erasing 64 Kibyte @ e30000 -- 44 % complete
Erasing 64 Kibyte @ e40000 -- 44 % complete
Erasing 64 Kibyte @ e50000 -- 44 % complete
Erasing 64 Kibyte @ e60000 -- 44 % complete
Erasing 64 Kibyte @ e70000 -- 45 % complete
Erasing 64 Kibyte @ e80000 -- 45 % complete
Erasing 64 Kibyte @ e90000 -- 45 % complete
Erasing 64 Kibyte @ ea0000 -- 45 % complete
Erasing 64 Kibyte @ eb0000 -- 45 % complete
Erasing 64 Kibyte @ ec0000 -- 46 % complete
Erasing 64 Kibyte @ ed0000 -- 46 % complete
Erasing 64 Kibyte @ ee0000 -- 46 % complete
Erasing 64 Kibyte @ ef0000 -- 46 % complete
Erasing 64 Kibyte @ f00000 -- 46 % complete
Erasing 64 Kibyte @ f10000 -- 47 % complete
Erasing 64 Kibyte @ f20000 -- 47 % complete tar: Read checkpoint 160000
Erasing 64 Kibyte @ f30000 -- 47 % complete
Erasing 64 Kibyte @ f40000 -- 47 % complete
Erasing 64 Kibyte @ f50000 -- 47 % complete
Erasing 64 Kibyte @ f60000 -- 48 % complete
Erasing 64 Kibyte @ f70000 -- 48 % complete
Erasing 64 Kibyte @ f80000 -- 48 % complete
Erasing 64 Kibyte @ f90000 -- 48 % complete
Erasing 64 Kibyte @ fa0000 -- 48 % complete
Erasing 64 Kibyte @ fb0000 -- 49 % complete
Erasing 64 Kibyte @ fc0000 -- 49 % complete
Erasing 64 Kibyte @ fd0000 -- 49 % complete
Erasing 64 Kibyte @ fe0000 -- 49 % complete
Erasing 64 Kibyte @ ff0000 -- 49 % complete
Erasing 64 Kibyte @ 1000000 -- 50 % complete tar: Read checkpoint 170000
Erasing 64 Kibyte @ 1010000 -- 50 % complete
Erasing 64 Kibyte @ 1020000 -- 50 % complete
Erasing 64 Kibyte @ 1030000 -- 50 % complete
Erasing 64 Kibyte @ 1040000 -- 50 % complete
Erasing 64 Kibyte @ 1050000 -- 50 % complete
Erasing 64 Kibyte @ 1060000 -- 51 % complete
Erasing 64 Kibyte @ 1070000 -- 51 % complete
Erasing 64 Kibyte @ 1080000 -- 51 % complete
Erasing 64 Kibyte @ 1090000 -- 51 % complete
Erasing 64 Kibyte @ 10a0000 -- 51 % complete
Erasing 64 Kibyte @ 10b0000 -- 52 % complete
Erasing 64 Kibyte @ 10c0000 -- 52 % complete
Erasing 64 Kibyte @ 10d0000 -- 52 % complete
Erasing 64 Kibyte @ 10e0000 -- 52 % complete
Erasing 64 Kibyte @ 10f0000 -- 52 % complete
Erasing 64 Kibyte @ 1100000 -- 53 % complete
Erasing 64 Kibyte @ 1110000 -- 53 % complete tar: Read checkpoint 180000
Erasing 64 Kibyte @ 1120000 -- 53 % complete
Erasing 64 Kibyte @ 1130000 -- 53 % complete
Erasing 64 Kibyte @ 1140000 -- 53 % complete
Erasing 64 Kibyte @ 1150000 -- 54 % complete
Erasing 64 Kibyte @ 1160000 -- 54 % complete
Erasing 64 Kibyte @ 1170000 -- 54 % complete
Erasing 64 Kibyte @ 1180000 -- 54 % complete
Erasing 64 Kibyte @ 1190000 -- 54 % complete
Erasing 64 Kibyte @ 11a0000 -- 55 % complete
Erasing 64 Kibyte @ 11b0000 -- 55 % complete
Erasing 64 Kibyte @ 11c0000 -- 55 % complete
Erasing 64 Kibyte @ 11d0000 -- 55 % complete
Erasing 64 Kibyte @ 11e0000 -- 55 % complete
Erasing 64 Kibyte @ 11f0000 -- 56 % complete
Erasing 64 Kibyte @ 1200000 -- 56 % complete tar: Read checkpoint 190000
Erasing 64 Kibyte @ 1210000 -- 56 % complete
Erasing 64 Kibyte @ 1220000 -- 56 % complete
Erasing 64 Kibyte @ 1230000 -- 56 % complete
Erasing 64 Kibyte @ 1240000 -- 57 % complete
Erasing 64 Kibyte @ 1250000 -- 57 % complete
Erasing 64 Kibyte @ 1260000 -- 57 % complete
Erasing 64 Kibyte @ 1270000 -- 57 % complete
Erasing 64 Kibyte @ 1280000 -- 57 % complete
Erasing 64 Kibyte @ 1290000 -- 58 % complete
Erasing 64 Kibyte @ 12a0000 -- 58 % complete
Erasing 64 Kibyte @ 12b0000 -- 58 % complete
Erasing 64 Kibyte @ 12c0000 -- 58 % complete
Erasing 64 Kibyte @ 12d0000 -- 58 % complete
Erasing 64 Kibyte @ 12e0000 -- 58 % complete
Erasing 64 Kibyte @ 12f0000 -- 59 % complete tar: Read checkpoint 200000
Erasing 64 Kibyte @ 1300000 -- 59 % complete
Erasing 64 Kibyte @ 1310000 -- 59 % complete
Erasing 64 Kibyte @ 1320000 -- 59 % complete
Erasing 64 Kibyte @ 1330000 -- 59 % complete
Erasing 64 Kibyte @ 1340000 -- 60 % complete
Erasing 64 Kibyte @ 1350000 -- 60 % complete
Erasing 64 Kibyte @ 1360000 -- 60 % complete
Erasing 64 Kibyte @ 1370000 -- 60 % complete
Erasing 64 Kibyte @ 1380000 -- 60 % complete
Erasing 64 Kibyte @ 1390000 -- 61 % complete
Erasing 64 Kibyte @ 13a0000 -- 61 % complete
Erasing 64 Kibyte @ 13b0000 -- 61 % complete
Erasing 64 Kibyte @ 13c0000 -- 61 % complete
Erasing 64 Kibyte @ 13d0000 -- 61 % complete
Erasing 64 Kibyte @ 13e0000 -- 62 % complete tar: Read checkpoint 210000
Erasing 64 Kibyte @ 13f0000 -- 62 % complete
Erasing 64 Kibyte @ 1400000 -- 62 % complete
Erasing 64 Kibyte @ 1410000 -- 62 % complete
Erasing 64 Kibyte @ 1420000 -- 62 % complete
Erasing 64 Kibyte @ 1430000 -- 63 % complete
Erasing 64 Kibyte @ 1440000 -- 63 % complete
Erasing 64 Kibyte @ 1450000 -- 63 % complete
Erasing 64 Kibyte @ 1460000 -- 63 % complete
Erasing 64 Kibyte @ 1470000 -- 63 % complete
Erasing 64 Kibyte @ 1480000 -- 64 % complete
Erasing 64 Kibyte @ 1490000 -- 64 % complete
Erasing 64 Kibyte @ 14a0000 -- 64 % complete
Erasing 64 Kibyte @ 14b0000 -- 64 % complete
Erasing 64 Kibyte @ 14c0000 -- 64 % complete tar: Read checkpoint 220000
Erasing 64 Kibyte @ 14d0000 -- 65 % complete
Erasing 64 Kibyte @ 14e0000 -- 65 % complete
Erasing 64 Kibyte @ 14f0000 -- 65 % complete
Erasing 64 Kibyte @ 1500000 -- 65 % complete
Erasing 64 Kibyte @ 1510000 -- 65 % complete
Erasing 64 Kibyte @ 1520000 -- 66 % complete
Erasing 64 Kibyte @ 1530000 -- 66 % complete
Erasing 64 Kibyte @ 1540000 -- 66 % complete
Erasing 64 Kibyte @ 1550000 -- 66 % complete
Erasing 64 Kibyte @ 1560000 -- 66 % complete
Erasing 64 Kibyte @ 1570000 -- 66 % complete
Erasing 64 Kibyte @ 1580000 -- 67 % complete
Erasing 64 Kibyte @ 1590000 -- 67 % complete
Erasing 64 Kibyte @ 15a0000 -- 67 % complete tar: Read checkpoint 230000
Erasing 64 Kibyte @ 15b0000 -- 67 % complete
Erasing 64 Kibyte @ 15c0000 -- 67 % complete
Erasing 64 Kibyte @ 15d0000 -- 68 % complete
Erasing 64 Kibyte @ 15e0000 -- 68 % complete
Erasing 64 Kibyte @ 15f0000 -- 68 % complete
Erasing 64 Kibyte @ 1600000 -- 68 % complete
Erasing 64 Kibyte @ 1610000 -- 68 % complete
Erasing 64 Kibyte @ 1620000 -- 69 % complete
Erasing 64 Kibyte @ 1630000 -- 69 % complete
Erasing 64 Kibyte @ 1640000 -- 69 % complete
Erasing 64 Kibyte @ 1650000 -- 69 % complete
Erasing 64 Kibyte @ 1660000 -- 69 % complete tar: Read checkpoint 240000
Erasing 64 Kibyte @ 1670000 -- 70 % complete
Erasing 64 Kibyte @ 1680000 -- 70 % complete
Erasing 64 Kibyte @ 1690000 -- 70 % complete
Erasing 64 Kibyte @ 16a0000 -- 70 % complete
Erasing 64 Kibyte @ 16b0000 -- 70 % complete
Erasing 64 Kibyte @ 16c0000 -- 71 % complete
Erasing 64 Kibyte @ 16d0000 -- 71 % complete
Erasing 64 Kibyte @ 16e0000 -- 71 % complete
Erasing 64 Kibyte @ 16f0000 -- 71 % complete
Erasing 64 Kibyte @ 1700000 -- 71 % complete
Erasing 64 Kibyte @ 1710000 -- 72 % complete tar: Read checkpoint 250000
Erasing 64 Kibyte @ 1720000 -- 72 % complete
Erasing 64 Kibyte @ 1730000 -- 72 % complete
Erasing 64 Kibyte @ 1740000 -- 72 % complete
Erasing 64 Kibyte @ 1750000 -- 72 % complete
Erasing 64 Kibyte @ 1760000 -- 73 % complete
Erasing 64 Kibyte @ 1770000 -- 73 % complete
Erasing 64 Kibyte @ 1780000 -- 73 % complete
Erasing 64 Kibyte @ 1790000 -- 73 % complete
Erasing 64 Kibyte @ 17a0000 -- 73 % complete
Erasing 64 Kibyte @ 17b0000 -- 74 % complete
Erasing 64 Kibyte @ 17c0000 -- 74 % complete
Erasing 64 Kibyte @ 17d0000 -- 74 % complete
Erasing 64 Kibyte @ 17e0000 -- 74 % complete
Erasing 64 Kibyte @ 17f0000 -- 74 % complete tar: Read checkpoint 260000
Erasing 64 Kibyte @ 1800000 -- 75 % complete
Erasing 64 Kibyte @ 1810000 -- 75 % complete
Erasing 64 Kibyte @ 1820000 -- 75 % complete
Erasing 64 Kibyte @ 1830000 -- 75 % complete
Erasing 64 Kibyte @ 1840000 -- 75 % complete
Erasing 64 Kibyte @ 1850000 -- 75 % complete
Erasing 64 Kibyte @ 1860000 -- 76 % complete
Erasing 64 Kibyte @ 1870000 -- 76 % complete
Erasing 64 Kibyte @ 1880000 -- 76 % complete
Erasing 64 Kibyte @ 1890000 -- 76 % complete
Erasing 64 Kibyte @ 18a0000 -- 76 % complete
Erasing 64 Kibyte @ 18b0000 -- 77 % complete tar: Read checkpoint 270000
Erasing 64 Kibyte @ 18c0000 -- 77 % complete
Erasing 64 Kibyte @ 18d0000 -- 77 % complete
Erasing 64 Kibyte @ 18e0000 -- 77 % complete
Erasing 64 Kibyte @ 18f0000 -- 77 % complete
Erasing 64 Kibyte @ 1900000 -- 78 % complete
Erasing 64 Kibyte @ 1910000 -- 78 % complete
Erasing 64 Kibyte @ 1920000 -- 78 % complete
Erasing 64 Kibyte @ 1930000 -- 78 % complete
Erasing 64 Kibyte @ 1940000 -- 78 % complete
Erasing 64 Kibyte @ 1950000 -- 79 % complete
Erasing 64 Kibyte @ 1960000 -- 79 % complete
Erasing 64 Kibyte @ 1970000 -- 79 % complete tar: Read checkpoint 280000
Erasing 64 Kibyte @ 1980000 -- 79 % complete
Erasing 64 Kibyte @ 1990000 -- 79 % complete
Erasing 64 Kibyte @ 19a0000 -- 80 % complete
Erasing 64 Kibyte @ 19b0000 -- 80 % complete
Erasing 64 Kibyte @ 19c0000 -- 80 % complete
Erasing 64 Kibyte @ 19d0000 -- 80 % complete
Erasing 64 Kibyte @ 19e0000 -- 80 % complete
Erasing 64 Kibyte @ 19f0000 -- 81 % complete
Erasing 64 Kibyte @ 1a00000 -- 81 % complete
Erasing 64 Kibyte @ 1a10000 -- 81 % complete
Erasing 64 Kibyte @ 1a20000 -- 81 % complete
Erasing 64 Kibyte @ 1a30000 -- 81 % complete
Erasing 64 Kibyte @ 1a40000 -- 82 % complete tar: Read checkpoint 290000
Erasing 64 Kibyte @ 1a50000 -- 82 % complete
Erasing 64 Kibyte @ 1a60000 -- 82 % complete
Erasing 64 Kibyte @ 1a70000 -- 82 % complete
Erasing 64 Kibyte @ 1a80000 -- 82 % complete
Erasing 64 Kibyte @ 1a90000 -- 83 % complete
Erasing 64 Kibyte @ 1aa0000 -- 83 % complete
Erasing 64 Kibyte @ 1ab0000 -- 83 % complete
Erasing 64 Kibyte @ 1ac0000 -- 83 % complete
Erasing 64 Kibyte @ 1ad0000 -- 83 % complete
Erasing 64 Kibyte @ 1ae0000 -- 83 % complete
Erasing 64 Kibyte @ 1af0000 -- 84 % complete tar: Read checkpoint 300000
Erasing 64 Kibyte @ 1b00000 -- 84 % complete
Erasing 64 Kibyte @ 1b10000 -- 84 % complete
Erasing 64 Kibyte @ 1b20000 -- 84 % complete
Erasing 64 Kibyte @ 1b30000 -- 84 % complete
Erasing 64 Kibyte @ 1b40000 -- 85 % complete
Erasing 64 Kibyte @ 1b50000 -- 85 % complete
Erasing 64 Kibyte @ 1b60000 -- 85 % complete
Erasing 64 Kibyte @ 1b70000 -- 85 % complete
Erasing 64 Kibyte @ 1b80000 -- 85 % complete
Erasing 64 Kibyte @ 1b90000 -- 86 % complete
Erasing 64 Kibyte @ 1ba0000 -- 86 % complete
Erasing 64 Kibyte @ 1bb0000 -- 86 % complete tar: Read checkpoint 310000
Erasing 64 Kibyte @ 1bc0000 -- 86 % complete
Erasing 64 Kibyte @ 1bd0000 -- 86 % complete
Erasing 64 Kibyte @ 1be0000 -- 87 % complete
Erasing 64 Kibyte @ 1bf0000 -- 87 % complete
Erasing 64 Kibyte @ 1c00000 -- 87 % complete
Erasing 64 Kibyte @ 1c10000 -- 87 % complete
Erasing 64 Kibyte @ 1c20000 -- 87 % complete
Erasing 64 Kibyte @ 1c30000 -- 88 % complete
Erasing 64 Kibyte @ 1c40000 -- 88 % complete
Erasing 64 Kibyte @ 1c50000 -- 88 % complete
Erasing 64 Kibyte @ 1c60000 -- 88 % complete tar: Read checkpoint 320000
Erasing 64 Kibyte @ 1c70000 -- 88 % complete
Erasing 64 Kibyte @ 1c80000 -- 89 % complete
Erasing 64 Kibyte @ 1c90000 -- 89 % complete
Erasing 64 Kibyte @ 1ca0000 -- 89 % complete
Erasing 64 Kibyte @ 1cb0000 -- 89 % complete
Erasing 64 Kibyte @ 1cc0000 -- 89 % complete
Erasing 64 Kibyte @ 1cd0000 -- 90 % complete
Erasing 64 Kibyte @ 1ce0000 -- 90 % complete
Erasing 64 Kibyte @ 1cf0000 -- 90 % complete
Erasing 64 Kibyte @ 1d00000 -- 90 % complete
Erasing 64 Kibyte @ 1d10000 -- 90 % complete tar: Read checkpoint 330000
Erasing 64 Kibyte @ 1d20000 -- 91 % complete
Erasing 64 Kibyte @ 1d30000 -- 91 % complete
Erasing 64 Kibyte @ 1d40000 -- 91 % complete
Erasing 64 Kibyte @ 1d50000 -- 91 % complete
Erasing 64 Kibyte @ 1d60000 -- 91 % complete
Erasing 64 Kibyte @ 1d70000 -- 91 % complete
Erasing 64 Kibyte @ 1d80000 -- 92 % complete
Erasing 64 Kibyte @ 1d90000 -- 92 % complete
Erasing 64 Kibyte @ 1da0000 -- 92 % complete
Erasing 64 Kibyte @ 1db0000 -- 92 % complete
Erasing 64 Kibyte @ 1dc0000 -- 92 % complete
Erasing 64 Kibyte @ 1dd0000 -- 93 % complete
Erasing 64 Kibyte @ 1de0000 -- 93 % complete tar: Read checkpoint 340000
Erasing 64 Kibyte @ 1df0000 -- 93 % complete
Erasing 64 Kibyte @ 1e00000 -- 93 % complete
Erasing 64 Kibyte @ 1e10000 -- 93 % complete
Erasing 64 Kibyte @ 1e20000 -- 94 % complete
Erasing 64 Kibyte @ 1e30000 -- 94 % complete
Erasing 64 Kibyte @ 1e40000 -- 94 % complete
Erasing 64 Kibyte @ 1e50000 -- 94 % complete
Erasing 64 Kibyte @ 1e60000 -- 94 % complete
Erasing 64 Kibyte @ 1e70000 -- 95 % complete
Erasing 64 Kibyte @ 1e80000 -- 95 % complete
Erasing 64 Kibyte @ 1e90000 -- 95 % complete tar: Read checkpoint 350000
Erasing 64 Kibyte @ 1ea0000 -- 95 % complete
Erasing 64 Kibyte @ 1eb0000 -- 95 % complete
Erasing 64 Kibyte @ 1ec0000 -- 96 % complete
Erasing 64 Kibyte @ 1ed0000 -- 96 % complete
Erasing 64 Kibyte @ 1ee0000 -- 96 % complete
Erasing 64 Kibyte @ 1ef0000 -- 96 % complete
Erasing 64 Kibyte @ 1f00000 -- 96 % complete
Erasing 64 Kibyte @ 1f10000 -- 97 % complete
Erasing 64 Kibyte @ 1f20000 -- 97 % complete
Erasing 64 Kibyte @ 1f30000 -- 97 % complete
Erasing 64 Kibyte @ 1f40000 -- 97 % complete
Erasing 64 Kibyte @ 1f50000 -- 97 % complete tar: Read checkpoint 360000
Erasing 64 Kibyte @ 1f60000 -- 98 % complete
Erasing 64 Kibyte @ 1f70000 -- 98 % complete
Erasing 64 Kibyte @ 1f80000 -- 98 % complete
Erasing 64 Kibyte @ 1f90000 -- 98 % complete
Erasing 64 Kibyte @ 1fa0000 -- 98 % complete
Erasing 64 Kibyte @ 1fb0000 -- 99 % complete
Erasing 64 Kibyte @ 1fc0000 -- 99 % complete
Erasing 64 Kibyte @ 1fd0000 -- 99 % complete
Erasing 64 Kibyte @ 1fe0000 -- 99 % complete
Erasing 64 Kibyte @ 1ff0000 -- 99 % complete
Erasing 64 Kibyte @ 1ff0000 -- 100 % complete
max_index=61
Writing br_bct_BR.bct (parittion: BCT) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/br_bct_BR.bct
Writing /qspi/internal/br_bct_BR.bct (2888 bytes) into  /dev/mtd0:0
Copied 2888 bytes from /qspi/internal/br_bct_BR.bct to address 0x00000000 in flash
Writing /qspi/internal/br_bct_BR.bct (2888 bytes) into  /dev/mtd0:4096
Copied 2888 bytes from /qspi/internal/br_bct_BR.bct to address 0x00001000 in flash
Writing /qspi/internal/br_bct_BR.bct (2888 bytes) into  /dev/mtd0:32768
Copied 2888 bytes from /qspi/internal/br_bct_BR.bct to address 0x00008000 in flash
Writing mb1_t194_prod_sigheader.bin.encrypt (parittion: mb1) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/mb1_t194_prod_sigheader.bin.encrypt
Writing /qspi/internal/mb1_t194_prod_sigheader.bin.encrypt (249312 bytes) into  /dev/mtd0:131072
tar: Read checkpoint 370000
Copied 249312 bytes from /qspi/internal/mb1_t194_prod_sigheader.bin.encrypt to address 0x00020000 in flash
Writing mb1_t194_prod_sigheader.bin.encrypt (parittion: mb1_b) into /dev/mtd0
Writing /qspi/internal/mb1_t194_prod_sigheader.bin.encrypt (249312 bytes) into  /dev/mtd0:393216
Copied 249312 bytes from /qspi/internal/mb1_t194_prod_sigheader.bin.encrypt to address 0x00060000 in flash
Writing mb1_cold_boot_bct_MB1_sigheader.bct.encrypt (parittion: MB1_BCT) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
Writing /qspi/internal/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt (30400 bytes) into  /dev/mtd0:655360
Copied 30400 bytes from /qspi/internal/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt to address 0x000a0000 in flash
Writing mb1_cold_boot_bct_MB1_sigheader.bct.encrypt (parittion: MB1_BCT_b) into /dev/mtd0
Writing /qspi/internal/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt (30400 bytes) into  /dev/mtd0:720896
Copied 30400 bytes from /qspi/internal/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt to address 0x000b0000 in flash
Writing mem_coldboot_sigheader.bct.encrypt (parittion: MEM_BCT) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/mem_coldboot_sigheader.bct.encrypt
Writing /qspi/internal/mem_coldboot_sigheader.bct.encrypt (198656 bytes) into  /dev/mtd0:786432
Copied 198656 bytes from /qspi/internal/mem_coldboot_sigheader.bct.encrypt to address 0x000c0000 in flash
Writing mem_coldboot_sigheader.bct.encrypt (parittion: MEM_BCT_b) into /dev/mtd0
Writing /qspi/internal/mem_coldboot_sigheader.bct.encrypt (198656 bytes) into  /dev/mtd0:1048576
tar: Read checkpoint 380000
Copied 198656 bytes from /qspi/internal/mem_coldboot_sigheader.bct.encrypt to address 0x00100000 in flash
Writing spe_t194_sigheader.bin.encrypt (parittion: spe-fw) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/spe_t194_sigheader.bin.encrypt
Writing /qspi/internal/spe_t194_sigheader.bin.encrypt (94960 bytes) into  /dev/mtd0:1310720
Copied 94960 bytes from /qspi/internal/spe_t194_sigheader.bin.encrypt to address 0x00140000 in flash
Writing spe_t194_sigheader.bin.encrypt (parittion: spe-fw_b) into /dev/mtd0
Writing /qspi/internal/spe_t194_sigheader.bin.encrypt (94960 bytes) into  /dev/mtd0:1572864
Copied 94960 bytes from /qspi/internal/spe_t194_sigheader.bin.encrypt to address 0x00180000 in flash
Writing nvtboot_t194_sigheader.bin.encrypt (parittion: mb2) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/nvtboot_t194_sigheader.bin.encrypt
Writing /qspi/internal/nvtboot_t194_sigheader.bin.encrypt (181232 bytes) into  /dev/mtd0:1835008
Copied 181232 bytes from /qspi/internal/nvtboot_t194_sigheader.bin.encrypt to address 0x001c0000 in flash
Writing nvtboot_t194_sigheader.bin.encrypt (parittion: mb2_b) into /dev/mtd0
Writing /qspi/internal/nvtboot_t194_sigheader.bin.encrypt (181232 bytes) into  /dev/mtd0:2097152
Copied 181232 bytes from /qspi/internal/nvtboot_t194_sigheader.bin.encrypt to address 0x00200000 in flash
Writing preboot_c10_prod_cr_sigheader.bin.encrypt (parittion: mts-preboot) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/preboot_c10_prod_cr_sigheader.bin.encrypt
Writing /qspi/internal/preboot_c10_prod_cr_sigheader.bin.encrypt (24016 bytes) into  /dev/mtd0:2359296
Copied 24016 bytes from /qspi/internal/preboot_c10_prod_cr_sigheader.bin.encrypt to address 0x00240000 in flash
Writing preboot_c10_prod_cr_sigheader.bin.encrypt (parittion: mts-preboot_b) into /dev/mtd0
Writing /qspi/internal/preboot_c10_prod_cr_sigheader.bin.encrypt (24016 bytes) into  /dev/mtd0:2424832
Copied 24016 bytes from /qspi/internal/preboot_c10_prod_cr_sigheader.bin.encrypt to address 0x00250000 in flash
Writing mce_c10_prod_cr_sigheader.bin.encrypt (parittion: mts-mce) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/mce_c10_prod_cr_sigheader.bin.encrypt
Writing /qspi/internal/mce_c10_prod_cr_sigheader.bin.encrypt (143200 bytes) into  /dev/mtd0:2490368
Copied 143200 bytes from /qspi/internal/mce_c10_prod_cr_sigheader.bin.encrypt to address 0x00260000 in flash
Writing mce_c10_prod_cr_sigheader.bin.encrypt (parittion: mts-mce_b) into /dev/mtd0
Writing /qspi/internal/mce_c10_prod_cr_sigheader.bin.encrypt (143200 bytes) into  /dev/mtd0:2686976
Copied 143200 bytes from /qspi/internal/mce_c10_prod_cr_sigheader.bin.encrypt to address 0x00290000 in flash
Writing mts_c10_prod_cr_sigheader.bin.encrypt (parittion: mts-proper) into /dev/mtd0
tar: Read checkpoint 390000
Sha1 checksum matched for /qspi/internal/mts_c10_prod_cr_sigheader.bin.encrypt
Writing /qspi/internal/mts_c10_prod_cr_sigheader.bin.encrypt (3430416 bytes) into  /dev/mtd0:2883584
tar: Read checkpoint 400000
tar: Read checkpoint 410000
tar: Read checkpoint 420000
Copied 3430416 bytes from /qspi/internal/mts_c10_prod_cr_sigheader.bin.encrypt to address 0x002c0000 in flash
Writing mts_c10_prod_cr_sigheader.bin.encrypt (parittion: mts-proper_b) into /dev/mtd0
Writing /qspi/internal/mts_c10_prod_cr_sigheader.bin.encrypt (3430416 bytes) into  /dev/mtd0:7077888
Writing kernel partition done
writing item=52, 1:3:kernel_b, 15099514880, 67108864, boot_sigheader.img.encrypt, 41732096, fixed-<reserved>-3, d260e548457f90b096ba8057d4059a36e19eee6b
Writing kernel_b partition with boot_sigheader.img.encrypt
dd if=/media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/internal/boot_sigheader.img.encrypt of=/dev/sdb bs=1K skip=0  seek=14745620 count=40754
tar: Read checkpoint 430000
tar: Read checkpoint 440000
tar: Read checkpoint 450000
Copied 3430416 bytes from /qspi/internal/mts_c10_prod_cr_sigheader.bin.encrypt to address 0x006c0000 in flash
Writing warmboot_t194_prod_sigheader.bin.encrypt (parittion: sc7) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/warmboot_t194_prod_sigheader.bin.encrypt
Writing /qspi/internal/warmboot_t194_prod_sigheader.bin.encrypt (65504 bytes) into  /dev/mtd0:11272192
Copied 65504 bytes from /qspi/internal/warmboot_t194_prod_sigheader.bin.encrypt to address 0x00ac0000 in flash
Writing warmboot_t194_prod_sigheader.bin.encrypt (parittion: sc7_b) into /dev/mtd0
Writing /qspi/internal/warmboot_t194_prod_sigheader.bin.encrypt (65504 bytes) into  /dev/mtd0:11403264
Copied 65504 bytes from /qspi/internal/warmboot_t194_prod_sigheader.bin.encrypt to address 0x00ae0000 in flash
Writing slot_metadata.bin (parittion: SMD) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/slot_metadata.bin
Writing /qspi/internal/slot_metadata.bin (191 bytes) into  /dev/mtd0:11534336
Copied 191 bytes from /qspi/internal/slot_metadata.bin to address 0x00b00000 in flash
Writing slot_metadata.bin (parittion: SMD_b) into /dev/mtd0
Writing /qspi/internal/slot_metadata.bin (191 bytes) into  /dev/mtd0:11599872
Copied 191 bytes from /qspi/internal/slot_metadata.bin to address 0x00b10000 in flash
Writing xusb_sil_rel_fw_sigheader.encrypt (parittion: xusb-fw) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/xusb_sil_rel_fw_sigheader.encrypt
Writing /qspi/internal/xusb_sil_rel_fw_sigheader.encrypt (133120 bytes) into  /dev/mtd0:11665408
Copied 133120 bytes from /qspi/internal/xusb_sil_rel_fw_sigheader.encrypt to address 0x00b20000 in flash
Writing xusb_sil_rel_fw_sigheader.encrypt (parittion: xusb-fw_b) into /dev/mtd0
Writing /qspi/internal/xusb_sil_rel_fw_sigheader.encrypt (133120 bytes) into  /dev/mtd0:11862016
Copied 133120 bytes from /qspi/internal/xusb_sil_rel_fw_sigheader.encrypt to address 0x00b50000 in flash
Writing cboot_t194_sigheader.bin.encrypt (parittion: cpu-bootloader) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/cboot_t194_sigheader.bin.encrypt
Writing /qspi/internal/cboot_t194_sigheader.bin.encrypt (469840 bytes) into  /dev/mtd0:12058624
Copied 469840 bytes from /qspi/internal/cboot_t194_sigheader.bin.encrypt to address 0x00b80000 in flash
Writing cboot_t194_sigheader.bin.encrypt (parittion: cpu-bootloader_b) into /dev/mtd0
Writing /qspi/internal/cboot_t194_sigheader.bin.encrypt (469840 bytes) into  /dev/mtd0:13500416
tar: Read checkpoint 460000
Copied 469840 bytes from /qspi/internal/cboot_t194_sigheader.bin.encrypt to address 0x00ce0000 in flash
Writing tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt (parittion: bootloader-dtb) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
Writing /qspi/internal/tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt (208736 bytes) into  /dev/mtd0:14942208
Copied 208736 bytes from /qspi/internal/tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt to address 0x00e40000 in flash
Writing tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt (parittion: bootloader-dtb_b) into /dev/mtd0
Writing /qspi/internal/tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt (208736 bytes) into  /dev/mtd0:15400960
Copied 208736 bytes from /qspi/internal/tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt to address 0x00eb0000 in flash
Writing bmp.blob (parittion: BMP) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/bmp.blob
Writing /qspi/internal/bmp.blob (149554 bytes) into  /dev/mtd0:15859712
Copied 149554 bytes from /qspi/internal/bmp.blob to address 0x00f20000 in flash
Writing bmp.blob (parittion: BMP_b) into /dev/mtd0
Writing /qspi/internal/bmp.blob (149554 bytes) into  /dev/mtd0:16056320
Copied 149554 bytes from /qspi/internal/bmp.blob to address 0x00f50000 in flash
Writing tos-trusty_t194_sigheader.img.encrypt (parittion: secure-os) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/tos-trusty_t194_sigheader.img.encrypt
Writing /qspi/internal/tos-trusty_t194_sigheader.img.encrypt (410560 bytes) into  /dev/mtd0:16252928
tar: Read checkpoint 470000
Copied 410560 bytes from /qspi/internal/tos-trusty_t194_sigheader.img.encrypt to address 0x00f80000 in flash
Writing tos-trusty_t194_sigheader.img.encrypt (parittion: secure-os_b) into /dev/mtd0
Writing /qspi/internal/tos-trusty_t194_sigheader.img.encrypt (410560 bytes) into  /dev/mtd0:18874368
Copied 410560 bytes from /qspi/internal/tos-trusty_t194_sigheader.img.encrypt to address 0x01200000 in flash
Writing eks_sigheader.img.encrypt (parittion: eks) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/eks_sigheader.img.encrypt
Writing /qspi/internal/eks_sigheader.img.encrypt (5136 bytes) into  /dev/mtd0:21495808
Copied 5136 bytes from /qspi/internal/eks_sigheader.img.encrypt to address 0x01480000 in flash
Writing eks_sigheader.img.encrypt (parittion: eks_b) into /dev/mtd0
Writing /qspi/internal/eks_sigheader.img.encrypt (5136 bytes) into  /dev/mtd0:21561344
Copied 5136 bytes from /qspi/internal/eks_sigheader.img.encrypt to address 0x01490000 in flash
Writing adsp-fw_sigheader.bin.encrypt (parittion: adsp-fw) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/adsp-fw_sigheader.bin.encrypt
Writing /qspi/internal/adsp-fw_sigheader.bin.encrypt (81312 bytes) into  /dev/mtd0:21626880
Copied 81312 bytes from /qspi/internal/adsp-fw_sigheader.bin.encrypt to address 0x014a0000 in flash
Writing adsp-fw_sigheader.bin.encrypt (parittion: adsp-fw_b) into /dev/mtd0
Writing /qspi/internal/adsp-fw_sigheader.bin.encrypt (81312 bytes) into  /dev/mtd0:22675456
Copied 81312 bytes from /qspi/internal/adsp-fw_sigheader.bin.encrypt to address 0x015a0000 in flash
Writing camera-rtcpu-rce_sigheader.img.encrypt (parittion: rce-fw) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/camera-rtcpu-rce_sigheader.img.encrypt
Writing /qspi/internal/camera-rtcpu-rce_sigheader.img.encrypt (272752 bytes) into  /dev/mtd0:23724032
tar: Read checkpoint 480000
Copied 272752 bytes from /qspi/internal/camera-rtcpu-rce_sigheader.img.encrypt to address 0x016a0000 in flash
Writing camera-rtcpu-rce_sigheader.img.encrypt (parittion: rce-fw_b) into /dev/mtd0
Writing /qspi/internal/camera-rtcpu-rce_sigheader.img.encrypt (272752 bytes) into  /dev/mtd0:24772608
Copied 272752 bytes from /qspi/internal/camera-rtcpu-rce_sigheader.img.encrypt to address 0x017a0000 in flash
[ 179]: l4t_flash_from_kernel: Warning: skip writing sce-fw partition as no image is specified
[ 179]: l4t_flash_from_kernel: Warning: skip writing sce-fw_b partition as no image is specified
Writing bpmp_t194_sigheader.bin.encrypt (parittion: bpmp-fw) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/bpmp_t194_sigheader.bin.encrypt
Writing /qspi/internal/bpmp_t194_sigheader.bin.encrypt (856352 bytes) into  /dev/mtd0:27918336
tar: Read checkpoint 490000
Copied 856352 bytes from /qspi/internal/bpmp_t194_sigheader.bin.encrypt to address 0x01aa0000 in flash
Writing bpmp_t194_sigheader.bin.encrypt (parittion: bpmp-fw_b) into /dev/mtd0
Writing /qspi/internal/bpmp_t194_sigheader.bin.encrypt (856352 bytes) into  /dev/mtd0:29491200
Copied 856352 bytes from /qspi/internal/bpmp_t194_sigheader.bin.encrypt to address 0x01c20000 in flash
Writing tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt (parittion: bpmp-fw-dtb) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt
Writing /qspi/internal/tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt (199808 bytes) into  /dev/mtd0:31064064
Copied 199808 bytes from /qspi/internal/tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt to address 0x01da0000 in flash
Writing tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt (parittion: bpmp-fw-dtb_b) into /dev/mtd0
Writing /qspi/internal/tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt (199808 bytes) into  /dev/mtd0:32112640
tar: Read checkpoint 500000
Copied 199808 bytes from /qspi/internal/tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt to address 0x01ea0000 in flash
[ 186]: l4t_flash_from_kernel: Warning: skip writing CPUBL-CFG partition as no image is specified
[ 186]: l4t_flash_from_kernel: Warning: skip writing CPUBL-CFG_b partition as no image is specified
Writing qspi_bootblob_ver.txt (parittion: VER) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/qspi_bootblob_ver.txt
Writing /qspi/internal/qspi_bootblob_ver.txt (100 bytes) into  /dev/mtd0:33292288
Copied 100 bytes from /qspi/internal/qspi_bootblob_ver.txt to address 0x01fc0000 in flash
Writing qspi_bootblob_ver.txt (parittion: VER_b) into /dev/mtd0
Writing /qspi/internal/qspi_bootblob_ver.txt (100 bytes) into  /dev/mtd0:33357824
Copied 100 bytes from /qspi/internal/qspi_bootblob_ver.txt to address 0x01fd0000 in flash
Writing gpt_secondary_3_0.bin (parittion: secondary_gpt) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/gpt_secondary_3_0.bin
Writing /qspi/internal/gpt_secondary_3_0.bin (16896 bytes) into  /dev/mtd0:33537536
Copied 16896 bytes from /qspi/internal/gpt_secondary_3_0.bin to address 0x01ffbe00 in flash
Reach the end of the SPI device
[ 186]: l4t_flash_from_kernel: Successfully flash the qspi
[ 186]: l4t_flash_from_kernel: Flashing success
40754+0 records in
40754+0 records out
41732096 bytes (42 MB, 40 MiB) copied, 32.9536 s, 1.3 MB/s
Writing kernel_b partition done
writing item=53, 1:3:kernel-dtb, 15166623744, 458752, kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt, 208736, fixed-<reserved>-4, 2df19e4ca092cc7feffbd3240f74ffa12edccfd3
writing item=3, 9:0:kernel, 510027386880, 67108864, boot_sigheader.img.encrypt, 41732096, fixed-<reserved>-2, 0d472a22a20a39d12a3763a3d003cae6f65edbde
Writing kernel-dtb partition with kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
208736 bytes from /media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/internal/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt to /dev/sdb: 1KB block=203 remainder=864
dd if=/media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/internal/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt of=/dev/sdb bs=1K skip=0  seek=14811156 count=203
41732096 bytes from /media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/external/boot_sigheader.img.encrypt to /dev/sde: 1KB block=40754 remainder=0
dd if=/media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/external/boot_sigheader.img.encrypt of=/dev/sde bs=1K skip=0  seek=498073620 count=40754
203+0 records in
203+0 records out
207872 bytes (208 kB, 203 KiB) copied, 0.0759899 s, 2.7 MB/s
dd if=/media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/internal/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt of=/dev/sdb bs=1 skip=207872  seek=15166831616 count=864
864+0 records in
864+0 records out
864 bytes copied, 0.0239891 s, 36.0 kB/s
Writing kernel-dtb partition done
writing item=54, 1:3:kernel-dtb_b, 15167082496, 458752, kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt, 208736, fixed-<reserved>-5, 2df19e4ca092cc7feffbd3240f74ffa12edccfd3
Writing kernel-dtb_b partition with kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
dd if=/media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/internal/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt of=/dev/sdb bs=1K skip=0  seek=14811604 count=203
203+0 records in
203+0 records out
207872 bytes (208 kB, 203 KiB) copied, 0.235929 s, 881 kB/s
dd if=/media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/internal/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt of=/dev/sdb bs=1 skip=207872  seek=15167290368 count=864
864+0 records in
864+0 records out
864 bytes copied, 0.00073782 s, 1.2 MB/s
Writing kernel-dtb_b partition done
writing item=55, 1:3:recovery, 15167541248, 66060288, recovery_sigheader.img.encrypt, 49489920, fixed-<reserved>-6, cf498d13e941bb1a2a2d889822f28b58dd9c2b88
Writing recovery partition with recovery_sigheader.img.encrypt
49489920 bytes from /media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/internal/recovery_sigheader.img.encrypt to /dev/sdb: 1KB block=48330 remainder=0
dd if=/media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/internal/recovery_sigheader.img.encrypt of=/dev/sdb bs=1K skip=0  seek=14812052 count=48330
40754+0 records in
40754+0 records out
41732096 bytes (42 MB, 40 MiB) copied, 10.9717 s, 3.8 MB/s
writing item=4, 9:0:kernel_b, 510094495744, 67108864, boot_sigheader.img.encrypt, 41732096, fixed-<reserved>-3, 0d472a22a20a39d12a3763a3d003cae6f65edbde
dd if=/media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/external/boot_sigheader.img.encrypt of=/dev/sde bs=1K skip=0  seek=498139156 count=40754
48330+0 records in
48330+0 records out
49489920 bytes (49 MB, 47 MiB) copied, 13.7447 s, 3.6 MB/s
Writing recovery partition done
writing item=56, 1:3:recovery-dtb, 15233601536, 524288, tegra194-p3668-all-p3509-0000.dtb_sigheader.rec.encrypt, 208736, fixed-<reserved>-7, 910cb0981054abb76587f7f6bc09854472316243
Writing recovery-dtb partition with tegra194-p3668-all-p3509-0000.dtb_sigheader.rec.encrypt
208736 bytes from /media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/internal/tegra194-p3668-all-p3509-0000.dtb_sigheader.rec.encrypt to /dev/sdb: 1KB block=203 remainder=864
dd if=/media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/internal/tegra194-p3668-all-p3509-0000.dtb_sigheader.rec.encrypt of=/dev/sdb bs=1K skip=0  seek=14876564 count=203
203+0 records in
203+0 records out
207872 bytes (208 kB, 203 KiB) copied, 0.10304 s, 2.0 MB/s
dd if=/media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/internal/tegra194-p3668-all-p3509-0000.dtb_sigheader.rec.encrypt of=/dev/sdb bs=1 skip=207872  seek=15233809408 count=864
864+0 records in
864+0 records out
864 bytes copied, 0.00547652 s, 158 kB/s
Writing recovery-dtb partition done
writing item=57, 1:3:kernel-bootctrl, 15234125824, 262144, kernel_bootctrl.bin, 20, fixed-<reserved>-8, 6768033e216468247bd031a0a2d9876d79818f8f
Writing kernel-bootctrl partition with kernel_bootctrl.bin
20 bytes from /media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/internal/kernel_bootctrl.bin to /dev/sdb: 1KB block=0 remainder=20
dd if=/media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/internal/kernel_bootctrl.bin of=/dev/sdb bs=1 skip=0  seek=15234125824 count=20
20+0 records in
20+0 records out
20 bytes copied, 0.00552296 s, 3.6 kB/s
Writing kernel-bootctrl partition done
writing item=58, 1:3:kernel-bootctrl_b, 15234387968, 262144, kernel_bootctrl.bin, 20, fixed-<reserved>-9, 6768033e216468247bd031a0a2d9876d79818f8f
Writing kernel-bootctrl_b partition with kernel_bootctrl.bin
dd if=/media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/internal/kernel_bootctrl.bin of=/dev/sdb bs=1 skip=0  seek=15234387968 count=20
20+0 records in
20+0 records out
20 bytes copied, 0.0214813 s, 0.9 kB/s
Writing kernel-bootctrl_b partition done
writing item=59, 1:3:RECROOTFS, 15234650112, 314572800, , , fixed-<reserved>-10,
[ 243]: l4t_flash_from_kernel: Warning: skip writing RECROOTFS partition as no image is specified
writing item=60, 1:3:UDA, 15549222912, 208760320, , , expand-<reserved>-11,
[ 243]: l4t_flash_from_kernel: Warning: skip writing UDA partition as no image is specified
writing item=61, 1:3:secondary_gpt, 15757983232, 16896, gpt_secondary_1_3.bin, 16896, fixed-<reserved>-0, b1840b6170b9a3fe1220a128066251ff9ca5c1d2
[ 243]: l4t_flash_from_kernel: Successfully flash the emmc
40754+0 records in
40754+0 records out
41732096 bytes (42 MB, 40 MiB) copied, 8.80521 s, 4.7 MB/s
writing item=5, 9:0:kernel-dtb, 510161604608, 458752, kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt, 208736, fixed-<reserved>-4, 910cb0981054abb76587f7f6bc09854472316243
208736 bytes from /media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/external/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt to /dev/sde: 1KB block=203 remainder=864
dd if=/media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/external/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt of=/dev/sde bs=1K skip=0  seek=498204692 count=203
203+0 records in
203+0 records out
207872 bytes (208 kB, 203 KiB) copied, 0.0623721 s, 3.3 MB/s
dd if=/media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/external/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt of=/dev/sde bs=1 skip=207872  seek=510161812480 count=864
864+0 records in
864+0 records out
864 bytes copied, 0.00715446 s, 121 kB/s
writing item=6, 9:0:kernel-dtb_b, 510162063360, 458752, kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt, 208736, fixed-<reserved>-5, 910cb0981054abb76587f7f6bc09854472316243
dd if=/media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/external/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt of=/dev/sde bs=1K skip=0  seek=498205140 count=203
203+0 records in
203+0 records out
207872 bytes (208 kB, 203 KiB) copied, 0.160386 s, 1.3 MB/s
dd if=/media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/external/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt of=/dev/sde bs=1 skip=207872  seek=510162271232 count=864
864+0 records in
864+0 records out
864 bytes copied, 0.00333891 s, 259 kB/s
writing item=7, 9:0:recovery, 510162522112, 66060288, recovery_sigheader.img.encrypt, 49489920, fixed-<reserved>-6, 5be5bfa3c02fdc8f79b759deed25be3589db34a2
49489920 bytes from /media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/external/recovery_sigheader.img.encrypt to /dev/sde: 1KB block=48330 remainder=0
dd if=/media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/external/recovery_sigheader.img.encrypt of=/dev/sde bs=1K skip=0  seek=498205588 count=48330
48330+0 records in
48330+0 records out
49489920 bytes (49 MB, 47 MiB) copied, 7.81273 s, 6.3 MB/s
writing item=8, 9:0:recovery-dtb, 510228582400, 524288, tegra194-p3668-all-p3509-0000.dtb_sigheader.rec.encrypt, 208736, fixed-<reserved>-7, 910cb0981054abb76587f7f6bc09854472316243
208736 bytes from /media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/external/tegra194-p3668-all-p3509-0000.dtb_sigheader.rec.encrypt to /dev/sde: 1KB block=203 remainder=864
dd if=/media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/external/tegra194-p3668-all-p3509-0000.dtb_sigheader.rec.encrypt of=/dev/sde bs=1K skip=0  seek=498270100 count=203
203+0 records in
203+0 records out
207872 bytes (208 kB, 203 KiB) copied, 0.12401 s, 1.7 MB/s
dd if=/media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/external/tegra194-p3668-all-p3509-0000.dtb_sigheader.rec.encrypt of=/dev/sde bs=1 skip=207872  seek=510228790272 count=864
864+0 records in
864+0 records out
864 bytes copied, 0.00068502 s, 1.3 MB/s
writing item=9, 9:0:kernel-bootctrl, 510229106688, 262144, kernel_bootctrl.bin, 20, fixed-<reserved>-8, 6768033e216468247bd031a0a2d9876d79818f8f
20 bytes from /media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/external/kernel_bootctrl.bin to /dev/sde: 1KB block=0 remainder=20
dd if=/media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/external/kernel_bootctrl.bin of=/dev/sde bs=1 skip=0  seek=510229106688 count=20
20+0 records in
20+0 records out
20 bytes copied, 0.00074792 s, 26.7 kB/s
writing item=10, 9:0:kernel-bootctrl_b, 510229368832, 262144, kernel_bootctrl.bin, 20, fixed-<reserved>-9, 6768033e216468247bd031a0a2d9876d79818f8f
dd if=/media/yahboom/56f5e59f-13d5-4975-b596-5ab0954a29ac/Linux_for_Tegra/tools/kernel_flash/images/external/kernel_bootctrl.bin of=/dev/sde bs=1 skip=0  seek=510229368832 count=20
20+0 records in
20+0 records out
20 bytes copied, 0.0455427 s, 0.4 kB/s
writing item=11, 9:0:RECROOTFS, 510229630976, 314572800, , , fixed-<reserved>-10,
[ 256]: l4t_flash_from_kernel: Warning: skip writing RECROOTFS partition as no image is specified
writing item=12, 9:0:UDA, 510544203776, 1565969920, , , expand-<reserved>-11,
[ 256]: l4t_flash_from_kernel: Warning: skip writing UDA partition as no image is specified
writing item=13, 9:0:secondary_gpt, 512110173696, 16896, gpt_secondary_9_0.bin, 16896, fixed-<reserved>-0, 4090df458a19430d8147170cb2f24d028693ff75
[ 256]: l4t_flash_from_kernel: Successfully flash the external device
[ 256]: l4t_flash_from_kernel: Flashing success
[ 256]: l4t_flash_from_kernel: The device size indicated in the partition layout xml is smaller than the actual size. This utility will try to fix the GPT.
Note: The flash process might have added some nvidia-flash-* connections in
NetworkManager to set up USB ethernet through flashing port (L4t USB Device mode).
You might want to check your NetworkManager configuration if you have some special
configuration.
Reboot target
Run command: sync; { sleep 1; reboot; } >/dev/null & on root@fe80::1%ens160u2
Success
Cleaning up...
Hi, sorry for late reply.
Please put serial connection log when booting up here, flashing log does not help.
Does the screen show anything in UEFI? (the NVIDIA logo)
What carrier board and L4T version are you using?
